No sound recording, when using my DAW
alkemy007
I'm trying to capture the audio, when using my DAW (Reason), for the purpose of production videos, but, I don't get anything. It has something to do with me using the ASIO Komplete Audio 6 setting in my Reason preferences, as, when I change it to some of the other settings, I then get signal, but, those setting have latency issues. Is there any way to bypass this? Any help is appreciated.
OS: Windows 11
Sound Card: Komplete Audio 6
DAW: Reason
AaronD
Windoze audio is stupid. That's the entire reason that ASIO exists, to bypass the whole mess and talk directly between app and hardware. Neither Mac nor Linux needs that.
If a Windoze-standard loopback is too slow, then I don't know what to tell you, except to try a different loopback, a different computer, and/or a different OS. Windoze audio works for some people, but as you've found, it doesn't for everyone.
Lawrence_SoCal
Then some of stick with Windows for other reasons, and simply have to put up with nature of Windows OS audio sub-system... sigh..
What some DAWs have started to do is enable Windows Audio sub-system audio output from DAW (in Presonus, I believe it is called "Listen Bus")
Another common recommendation from years ago was to yuse Reaper's restream VST plugin. A number of related links I captured years ago, in case any of this helps you
https://myafton.com/help/pc-users-daw-output-to-obs/
How to Get Audio from Your DAW to OBS for Recording / Streaming (No Latency) Apr 15, 2020 https://www.youtube.com/watch?v=X-lFrkReAjk
Finally an easy way to stream Studio One with OBS
Reference/link to https://www.youtube.com/watch?v=rxZ3o1aTyPY
Get your DAW Audio Output in OBS Studio and send it to Twitch, Youtube, Skype, Discord, Zoom, etc...
110,525 views Mar 16, 2020 Vincent Diamante
ReaStream w/ ReaPlugs VST FX Suite: https://www.reaper.fm/reaplugs/
Send the audio of your DAW to OBS the right way with Reastream
https://www.reddit.com/r/Reaper/comments/jpzbjr/issues_with_reastream_standalone_plugin_in_obs/
https://willhelliwell.com/posts/record-your-daw-with-obs-and-reastream/
HOW TO RECORD YOUR DAW WITH OBS AND REASTREAM (WINDOWS ONLY) by willhelliwell October 23, 2020
https://forum.cockos.com/showthread.php?t=230684 Getting ReaStream to stream locally into OBS Studio [Solved]
