Question / Help no sound from usb audio interface
Jade708
Hi everyone I usually do streams from obs on my imac using a usb audio interface (duo-capture ex by Roland) I have been able to stream with that in the past and had to make a certain "profile" in the audio/midi configuration app on mac. Haven't streamed in a while and tried one today but there wasn't any sound.
In system preferences I put my output as well as input as "duo capture ex" like I usually do
In obs I had 3 profiles running to see which one worked: one as duo capture (which was the audio input in the source menu), built-in audio (the only one that worked) and "iShowU audio" which I made following a tutorial so I could stream sound coming from garageband (also wasn't picked up, also came through the duo capture)
my settings in obs and system preferences are the way I always have used them... the only settings I know nothing about are the settings from the midi/audio configuration app... I'm not sure at all but my guess is something happened to the profiles I made, they look fine but I'm not sure since I don't understand that at all... I just made them, following a tutorial on youtube that I'm unable to find anymore.
please help, it's so frustrating
