palaksetia
My current set up is:
DJM-S9 - taking the master out via XLR for both sides and sticking it into the USB interface, being controlled by a 2015 macbook pro
Behringer UMC202HD - taking the input from the DJM S9, and then connecting into a 2019 macbook pro for the streaming purposes for Twitch
The audio is coming into the interface, I can hear it via the headphone slot, and other applications, but I don't know why it's not coming into my OBS audio input capture when I select the device. Here's my log:
13:57:58.177: CPU Name: Intel(R) Core(TM) i5-8257U CPU @ 1.40GHz
13:57:58.177: CPU Speed: 1400MHz
13:57:58.177: Physical Cores: 4, Logical Cores: 8
13:57:58.177: Physical Memory: 8192MB Total
13:57:58.178: OS Name: Mac OS X (NSMACHOperatingSystem)
13:57:58.178: OS Version: Version 10.15.4 (Build 19E266)
13:57:58.178: Kernel Version: 19.4.0
13:57:58.190: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
13:57:58.190: Portable mode: false
13:57:58.553: OBS 24.0.6 (mac)
13:57:58.553: ---------------------------------
13:57:58.554: ---------------------------------
13:57:58.554: audio settings reset:
13:57:58.554: samples per sec: 44100
13:57:58.554: speakers: 2
13:57:58.555: ---------------------------------
13:57:58.555: Initializing OpenGL...
13:57:58.577: Loading up OpenGL on adapter Intel Inc. Intel(R) Iris(TM) Plus Graphics 645
13:57:58.577: OpenGL loaded successfully, version 4.1 INTEL-14.5.22, shading language 4.10
13:57:58.659: ---------------------------------
13:57:58.660: video settings reset:
13:57:58.660: base resolution: 1440x900
13:57:58.660: output resolution: 1440x900
13:57:58.660: downscale filter: Bicubic
13:57:58.660: fps: 60/1
13:57:58.660: format: NV12
13:57:58.660: YUV mode: 601/Partial
13:57:58.660: NV12 texture support not available
13:57:58.660: Audio monitoring device:
13:57:58.660: name: Default
13:57:58.660: id: default
13:57:58.660: ---------------------------------
13:57:58.662: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
13:57:58.672: os_dlopen(libpython3.7m.dylib->libpython3.7m.dylib): dlopen(libpython3.7m.dylib, 257): image not found
13:57:58.672:
13:57:58.672: [Python] Could not load library: libpython3.7m.dylib
13:57:58.749: No blackmagic support
13:57:58.814: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
13:57:58.868: [obs-browser]: Version 2.7.16
13:57:58.876: os_dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib->/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib): dlopen(/Applications/VLC.app/Contents/MacOS/lib/libvlccore.dylib, 257): image not found
13:57:58.876:
13:57:58.876: Couldn't find VLC installation, VLC video source disabled
13:57:58.876: ---------------------------------
13:57:58.876: Loaded Modules:
13:57:58.876: vlc-video.so
13:57:58.876: text-freetype2.so
13:57:58.876: rtmp-services.so
13:57:58.876: obs-x264.so
13:57:58.876: obs-vst.so
13:57:58.876: obs-transitions.so
13:57:58.876: obs-outputs.so
13:57:58.876: obs-libfdk.so
13:57:58.876: obs-filters.so
13:57:58.876: obs-ffmpeg.so
13:57:58.876: obs-browser.so
13:57:58.876: mac-vth264.so
13:57:58.876: mac-syphon.so
13:57:58.876: mac-decklink.so
13:57:58.876: mac-capture.so
13:57:58.876: mac-avcapture.so
13:57:58.876: linux-jack.so
13:57:58.876: image-source.so
13:57:58.876: frontend-tools.so
13:57:58.876: decklink-ouput-ui.so
13:57:58.876: coreaudio-encoder.so
13:57:58.877: os_dlopen(../obs-plugins/obs-browser->../obs-plugins/obs-browser.so): dlopen(../obs-plugins/obs-browser.so, 257): image not found
13:57:58.877:
13:57:58.877: ==== Startup complete ===============================================
13:57:58.901: All scene data cleared
13:57:58.901: ------------------------------------------------
13:57:58.940: coreaudio: device 'UMC202HD 192k' initialized
13:57:59.329: coreaudio: device 'UMC202HD 192k' initialized
13:57:59.330: Switched to scene 'Scene'
13:57:59.330: ------------------------------------------------
13:57:59.330: Loaded scenes:
13:57:59.330: - scene 'Scene':
13:57:59.335: - source: 'Image' (image_source)
13:57:59.335: - source: 'Audio Input Capture' (coreaudio_input_capture)
13:57:59.335: ------------------------------------------------
13:57:59.372: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds (source: Audio Input Capture)
13:57:59.372:
13:59:09.696: ---------------------------------
13:59:09.697: video settings reset:
13:59:09.697: base resolution: 1440x900
13:59:09.697: output resolution: 1440x900
13:59:09.697: downscale filter: Bicubic
13:59:09.697: fps: 60/1
13:59:09.697: format: NV12
13:59:09.697: YUV mode: 601/Partial
13:59:09.697: NV12 texture support not available
13:59:09.698: Settings changed (general, advanced)
13:59:09.698: ------------------------------------------------
13:59:58.603: User changed audio monitoring for source 'Audio Input Capture' to: monitor only
14:00:08.547: User changed audio monitoring for source 'Audio Input Capture' to: monitor and output
14:01:35.789: User Removed source 'Audio Input Capture' (coreaudio_input_capture) from scene 'Scene'
14:01:40.598: Video Capture Device: No device selected
14:01:40.599: User added source 'Video Capture Device' (av_capture_input) to scene 'Scene'
14:01:44.752: Video Capture Device: No device selected, stopping capture
14:01:49.945: User Removed source 'Video Capture Device' (av_capture_input) from scene 'Scene'
14:06:05.715: coreaudio: device 'MacBook Pro Microphone' initialized
14:06:05.717: User added source 'Audio Input Capture' (coreaudio_input_capture) to scene 'Scene'
14:06:07.662: coreaudio: device 'UMC202HD 192k' initialized
13:57:58.672:
13:57:58.876:
13:57:58.877:
13:57:59.372:
