ajhidell39
Hi all,
Basically my setup is elgato HD60 to capture which works fine, then I have an external soundcard (SPL crimson) with a mic plugged into it that works fine when I'm in a DAW/audio software but get no input when I'm in OBS.
I've had this exact same setup working in the past so I've no idea what's changed. Here's a log if that helps.
I have desktop audio 1 and mic audio 1 both set to default but have also selected the devices. Within windows audio settings I have SPL selected as my output device (which works fine) and the SPL's line in as the input, which is my only option.
My mic privacy settings are enabled for OBS and I've tried a separate audio input device but same result.
Any ideas? This is driving me mad. Thanks.
