So i have this problem where i start recording and it records the first few seconds of my game and then it freezes. When i watch back the recording i can only see a black screen but can hear my voice. My game sound doesn't record either. Please help!
20:40:37.345: CPU Name: Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
20:40:37.345: CPU Speed: 3192MHz
20:40:37.345: Physical Cores: 4, Logical Cores: 4
20:40:37.345: Physical Memory: 8094MB Total, 5369MB Free
20:40:37.345: Windows Version: 10.0 Build 14393 (revision: 1198; 64-bit)
20:40:37.345: Running as administrator: false
20:40:37.345: Aero is Enabled (Aero is always on for windows 8 and above)
20:40:37.345: Portable mode: false
20:40:37.354: OBS 19.0.3 (64bit, windows)
20:40:37.354: ---------------------------------
20:40:37.437: ---------------------------------
20:40:37.437: audio settings reset:
20:40:37.437: samples per sec: 44100
20:40:37.437: speakers: 2
20:40:37.438: ---------------------------------
20:40:37.438: Initializing D3D11...
20:40:37.438: Available Video Adapters:
20:40:37.440: Adapter 1: NVIDIA GeForce GTX 980
20:40:37.440: Dedicated VRAM: 4257939456
20:40:37.440: Shared VRAM: 4243654656
20:40:37.440: output 1: pos={0, 0}, size={1920, 1080}, attached=true
20:40:37.443: Loading up D3D11 on adapter NVIDIA GeForce GTX 980 (0)
20:40:37.464: D3D11 loaded successfully, feature level used: 45056
20:40:38.164: ---------------------------------
20:40:38.164: video settings reset:
20:40:38.164: base resolution: 1920x1080
20:40:38.164: output resolution: 1280x720
20:40:38.164: downscale filter: Bicubic
20:40:38.164: fps: 30/1
20:40:38.164: format: NV12
20:40:38.165: Audio monitoring device:
20:40:38.165: name: Standaard
20:40:38.165: id: default
20:40:38.165: ---------------------------------
20:40:38.168: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
20:40:38.182: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:40:38.184: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
20:40:38.184: Failed to initialize module 'enc-amf.dll'
20:40:38.219: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
20:40:38.220: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
20:40:38.221: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
20:40:38.222: Failed to load 'en-US' text for module: 'obs-browser.dll'
20:40:38.222: [browser_source: 'Version: 1.29.0']
20:40:38.259: NVENC supported
20:40:38.302: Couldn't find VLC installation, VLC video source disabled
20:40:38.327: No blackmagic support
20:40:38.359: ---------------------------------
20:40:38.359: Loaded Modules:
20:40:38.359: win-wasapi.dll
20:40:38.359: win-mf.dll
20:40:38.359: win-dshow.dll
20:40:38.359: win-decklink.dll
20:40:38.359: win-capture.dll
20:40:38.359: vlc-video.dll
20:40:38.359: text-freetype2.dll
20:40:38.360: rtmp-services.dll
20:40:38.360: obs-x264.dll
20:40:38.360: obs-vst.dll
20:40:38.360: obs-transitions.dll
20:40:38.360: obs-text.dll
20:40:38.360: obs-qsv11.dll
20:40:38.360: obs-outputs.dll
20:40:38.360: obs-filters.dll
20:40:38.360: obs-ffmpeg.dll
20:40:38.360: obs-browser.dll
20:40:38.360: image-source.dll
20:40:38.360: frontend-tools.dll
20:40:38.360: enc-amf.dll
20:40:38.360: coreaudio-encoder.dll
20:40:38.360: ==== Startup complete ===============================================
20:40:38.360: Service '' not found
20:40:38.360: No scene file found, creating default scene
20:40:38.361: All scene data cleared
20:40:38.361: ------------------------------------------------
20:40:38.456: WASAPI: Device 'Oortelefoon van hoofdtelefoon (Razer Kraken 7.1 Chroma)' initialized
20:40:38.475: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
20:40:38.487: WASAPI: Device 'Microfoon van hoofdtelefoon (Razer Kraken 7.1 Chroma)' initialized
20:40:38.487: Switched to scene 'Scène'
20:40:38.488: Failed to glob scene collections
20:40:38.489: CalculateFileHash: Failed to open file 'C:\Users\Gebruiker\AppData\Roaming\obs-studio\updates\manifest.json': 2
20:40:38.965: [rtmp-services plugin] Successfully updated file 'services.json' (version 65)
20:40:38.966: [rtmp-services plugin] Successfully updated package (version 65)
20:41:04.560:
20:41:04.560: ==== Auto-config wizard testing commencing ======
20:41:07.967: ---------------------------------
20:41:07.967: video settings reset:
20:41:07.967: base resolution: 1920x1080
20:41:07.967: output resolution: 1920x1080
20:41:07.967: downscale filter: Bicubic
20:41:07.967: fps: 60/1
20:41:07.967: format: NV12
20:41:08.000:
20:41:08.000: ==== Auto-config wizard testing stopping ========
20:41:16.121: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
20:41:18.569: User added source 'Gamecapture' (game_capture) to scene 'Scène'
20:42:34.259: User Removed source 'Gamecapture' (game_capture) from scene 'Scène'
20:42:45.082: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
20:42:59.736: User added source 'Gamecapture' (game_capture) to scene 'Scène'
20:43:02.786: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:02.789: [game-capture: 'Gamecapture'] using helper (compatibility hook)
20:43:02.819: [game-capture: 'Gamecapture'] hook not loaded yet, retrying..
20:43:04.787: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:05.585: [game-capture: 'Gamecapture'] capture stopped
20:43:06.802: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:06.818: [game-capture: 'Gamecapture'] capture stopped
20:43:10.819: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:10.835: [game-capture: 'Gamecapture'] capture stopped
20:43:14.836: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:14.852: [game-capture: 'Gamecapture'] capture stopped
20:43:18.852: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:18.868: [game-capture: 'Gamecapture'] capture stopped
20:43:22.869: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:22.885: [game-capture: 'Gamecapture'] capture stopped
20:43:26.886: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:26.902: [game-capture: 'Gamecapture'] capture stopped
20:43:30.903: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:30.918: [game-capture: 'Gamecapture'] capture stopped
20:43:34.920: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:34.935: [game-capture: 'Gamecapture'] capture stopped
20:43:38.936: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:38.952: [game-capture: 'Gamecapture'] capture stopped
20:43:39.171: rtmp-common.c: [initialize_output] Could not find service ''
20:43:39.172: rtmp-common.c: [initialize_output] Could not find service ''
20:43:39.173: rtmp-common.c: [initialize_output] Could not find service ''
20:43:39.174: rtmp-common.c: [initialize_output] Could not find service ''
20:43:39.200: rtmp-common.c: [initialize_output] Could not find service ''
20:43:42.953: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:42.969: [game-capture: 'Gamecapture'] capture stopped
20:43:43.034: Settings changed (general)
20:43:43.034: ------------------------------------------------
20:43:46.821: rtmp-common.c: [initialize_output] Could not find service ''
20:43:46.822: rtmp-common.c: [initialize_output] Could not find service ''
20:43:46.823: rtmp-common.c: [initialize_output] Could not find service ''
20:43:46.824: rtmp-common.c: [initialize_output] Could not find service ''
20:43:46.851: rtmp-common.c: [initialize_output] Could not find service ''
20:43:46.969: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:46.985: [game-capture: 'Gamecapture'] capture stopped
20:43:50.272: Settings changed (general)
20:43:50.272: ------------------------------------------------
20:43:50.987: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:51.002: [game-capture: 'Gamecapture'] capture stopped
20:43:55.005: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:55.019: [game-capture: 'Gamecapture'] capture stopped
20:43:55.191: Settings changed (general)
20:43:55.191: ------------------------------------------------
20:43:57.664: rtmp-common.c: [initialize_output] Could not find service ''
20:43:58.065: rtmp-common.c: [initialize_output] Could not find service ''
20:43:59.021: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:43:59.035: [game-capture: 'Gamecapture'] capture stopped
20:44:03.036: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:03.052: [game-capture: 'Gamecapture'] capture stopped
20:44:07.052: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:07.069: [game-capture: 'Gamecapture'] capture stopped
20:44:09.617: rtmp-common.c: [initialize_output] Could not find service ''
20:44:11.069: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:11.085: [game-capture: 'Gamecapture'] capture stopped
20:44:15.086: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:15.102: [game-capture: 'Gamecapture'] capture stopped
20:44:15.484: Settings changed (outputs)
20:44:15.484: ------------------------------------------------
20:44:19.103: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:19.119: [game-capture: 'Gamecapture'] capture stopped
20:44:19.131: rtmp-common.c: [initialize_output] Could not find service ''
20:44:19.916: Settings changed (outputs)
20:44:19.917: ------------------------------------------------
20:44:23.119: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:23.135: [game-capture: 'Gamecapture'] capture stopped
20:44:27.136: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:27.152: [game-capture: 'Gamecapture'] shared texture capture successful
20:44:32.585: [game-capture: 'Gamecapture'] capture window no longer exists, terminating capture
20:44:32.585: [game-capture: 'Gamecapture'] capture stopped
20:44:36.621: [game-capture: 'Gamecapture'] attempting to hook process: javaw.exe
20:44:36.641: [game-capture: 'Gamecapture'] shared texture capture successful
20:45:02.366: rtmp-common.c: [initialize_output] Could not find service ''
20:45:02.366: ---------------------------------
20:45:02.367: [NVENC encoder: 'simple_h264_recording'] settings:
20:45:02.367: rate_control: CQP
20:45:02.367: bitrate: 0
20:45:02.367: cqp: 16
20:45:02.367: keyint: 250
20:45:02.367: preset: hq
20:45:02.367: profile: high
20:45:02.367: level: auto
20:45:02.367: width: 1920
20:45:02.367: height: 1080
20:45:02.367: 2-pass: true
20:45:02.367: b-frames: 2
20:45:02.367: GPU: 0
20:45:02.367:
20:45:03.290: [Media Foundation AAC: 'simple_aac_recording']: encoder created
20:45:03.290: bitrate: 128
20:45:03.290: channels: 2
20:45:03.290: sample rate: 44100
20:45:03.290: bits-per-sample: 16
20:45:03.290:
20:45:03.309: ==== Recording Start ===============================================
20:45:03.309: [ffmpeg muxer: 'simple_file_output'] Writing file 'C:/Users/Gebruiker/Desktop/Recordings/2017-07-19 20-45-02.mp4'...
20:45:11.478: [ffmpeg muxer: 'simple_file_output'] Output of file 'C:/Users/Gebruiker/Desktop/Recordings/2017-07-19 20-45-02.mp4' stopped
20:45:11.478: Output 'simple_file_output': stopping
20:45:11.478: Output 'simple_file_output': Total encoded frames: 489
20:45:11.478: Output 'simple_file_output': Total drawn frames: 490
20:45:11.478: Output 'simple_file_output': Number of lagged frames due to rendering lag/stalls: 2 (0.4%)
20:45:11.478: ==== Recording Stop ================================================
20:46:17.759: rtmp-common.c: [initialize_output] Could not find service ''
20:46:17.760: rtmp-common.c: [initialize_output] Could not find service ''
20:46:17.761: rtmp-common.c: [initialize_output] Could not find service ''
20:46:17.793: rtmp-common.c: [initialize_output] Could not find service ''
20:46:19.457: rtmp-common.c: [initialize_output] Could not find service ''
20:41:04.560:
20:41:08.000:
20:45:02.367:
20:45:03.290:
