Bug Report No Audio when Live [M-Audio Delta 1010LT]
So i wanted to Stream again a bit, i tested my Audio while i Recorded a Video and everything was working fine (didnt checked that while i was Live because i trusted that recordings) , then i started the stream and was close to 1 Hour Online and was wondering myself why nobody is writing anything, then i ended the stream and watched my Video of my last Stream, no audio at all!
After i Disabled and activated both sources again in the Settings (not mixersettings) (Desktop/Mic) everything was working fine like it did in the Recordings and it should also do when u are Live!
(like that possible fix of that audiobug over a year ago)
interesting is that my Mixer said that my audio is getting sended perfectly!
My Setup:
Soundcard: (Pci card, no Onboard Soundcard) M-Audio Delta 1010LT (8in´s / Out´s)
CPU: FX 8120
GPU: R9 280X
RAM: 16GB
PSU: 750W
HDD: 1 TB
So i think that u didnt fixed that for that old card because not a lot people using that for streaming!
Thank u if u need more informations, i will try to provide them to u!
Narcogen
Check your track assignments in Edit > Advanced Audio Properties, and which track is set to stream in Output.
You can record multiple audio tracks, but you can only stream one. So if you have multiple sources isolated on separate tracks, you need to make at least one track with all audio on it, and select that as your streaming audio track.
i did that, and this didnt worked.
tried all tracks (desktop on track 1 mic on 1) and 2 tracks (desktop on 1 mic on 2), nothing worked.
after disabling the audios and reactivating them solved the problem, iam an advanced user, but thank u for ur advice!
also, u can have so many tracks u want on different outputs, the audio onstream when ur live gets mixed down to Stereo.
greetings
