Hello.
I just got native instruments komplete kontrol and an audio6 2 channel sound card for my windows 10 pro system. I've got it set as my default recording device and though I can hear sound from komplete kontrol when I have a vst inserted into reaper and I can record a track, OBS isn't capturing the audio to a test recording. I've got desktop audio checked and since I'm blind and use a screen reader, it seems a bit hit and miss with whether other options need to be checked.
The thing is, before, when my roland fa08 was the default recording device, and desktop audio was selected, I had no problems with the software capturing sound from that device.
I am using asio as my sound driver and don't want to change that to something else as that's what's recommended by others who I've talked to about this isue.
I'd appreciate any help you can provide regarding this situation.
i appreciate it.
i appreciate it.
