Question / Help Need URGENT help! OBS not showing features? [Willing to pay good $]
Zaidyn
I just installed OBS on my Mac, and I have 2 Logitech C922 Pro webcams connected as well. OBS Handles these both, BUT I can't see the "Video settings" button, so therefore I can't zoom in my webcams, when I need to and zooming is supported.
If I right click on my video capture device then click properties there's no "Configure Video" or "Configure Crossfade" or whatever there. I can't change exposure levels, brightness, zoom, pan, etc etc.
I need URGENT help, please, it's for a client. Willing to pay $20 USD if someone can help me out in next 48 hours.
Thanks!
Zaidyn
https://itunes.apple.com/WebObjects/MZStore.woa/wa/viewSoftware?id=638332853&mt=12
Have you downloaded this app?
I control my 920 outside of OBS.
no need for compensation, just trying to help
Hello! Thanks for your quick reply!
I have tried that, the problem with that software, however, is that i'm running a system with 2 cameras. The Logitech Webcam software only supports 1 at a time; if I'm running one and want to change the other one, I have to completely exit the Logitech software, disconnect both cameras, connect the one I want to change, then connect the other one. Which is all a bit of a hassle, especially since it'll be live on Youtube.
Although, thanks heaps for your effort!
- Zaidyn
I see your point.
We have a second HDMI camera input from blackmagic mini recorder via thunderbolt.
If you have another cam the mini recorder or the BM web presenter work great.
Zaidyn
I see your point.
Alright, will definitely look into it.
You sure you don't want a bit of compensation?
Thanks HEAPS,
- Zaidyn
