Hi all~
Thanks in advance for any insight you may have to offer. I've tried including as much information as I can. As a result, the post was visually a lot so I've spoiler tagged some of the information for a less overwhelming presentation.
The issue: Frame drops due to network ongoing for a little over a week. The drops are seemingly severe at times. I switched ISPs about a month ago when my old ISP started to have similar issues. The new ISP ran fine for a while but, as of about a week ago, has begun to experience this issue(which I have yet to completely decide is coincidental). I'm reaching out here in hopes that someone might have a suggestion or notice something in the log that I have missed as continuing to troubleshoot and experiment during stream on my own has proven unsuccessful.
I'm sure I've tried some other things that I've forgotten to mention here as well. Truly, I'm not very knowledgeable in trying to troubleshoot this type of issue but have done an extensive amount of the Google for the sake of earnestly trying to figure this out on my own. Help, please!
OBS Log from yesterday
My download is 900+ Mbps and upload is 90+ Mbps on the new ISP. Old ISP values were around 500 up and 40ish down. I'm running an ethernet connection to my Windows 11 PC that has had all of its components(MOBO, CPU, RAM, GPU and PSU) all upgraded within the past year. Drivers for all appear to be up to date. In case it lends any insight, I'm now running on a Ryzen 7 7800X3D with 32GB DDR5 RAM on an ASRock B650 Steel Legend Wifi. My GPU is Radeon 9070XT and my PSU is an ASRock 1000W something or other.
-Ran the TwitchTest app in various parts of the day to determine if it might be a congestion issue. While the results are generally better in the day time, I'm not sure I see enough of a definitive result from the test to conclude that this is the core issue -- even if the results are, naturally, significantly worse when I am experiencing the issue.
-Ran the R1 TCP Optimizer as I found the suggestion on another thread here, to no avail.
-Had a technician from the new ISP come out and inspect. Not entirely sure he checked everything... but he *did* find water in the line and subsequently replaced said line.
-Bought a new router(TP-Link Archer 9300) in addition to running a direct connection to the modem for testing purposes; no joy.
-Toggled OBS settings for Network Optimizations in the Advanced tab, as well as toggling both TCP pacing and Dynamic bitrate settings. (Admittedly, I have yet to try streaming with TCP pacing deactivated since changing IP Family to IPv4 so at least that's a thing left to try.)
-Enabling QoS on my router to try to prioritize network traffic for the PC. Honestly, not certain I did this correctly but still get the same speedtest results while streaming and actively experiencing issues.
