Question / Help Need help with settings for CSGO stream.
pachenko404
So I've always had this issue of setting my counter strike global offensive stream to look good and to not be laggy on the viewers side or fps laggy on my side, a lot of people complain that when they watch the stream it buffers alot.
My Specs are
FX-8350 4.2GHZ
Radeon 7850 2GB OC
8GB RAM
My Download speed is 120mb/s
My Upload speed is 12mb/s
I also use 144hz monitor and I need more then 144 fps ingame for it to run and feel smooth with the settings.
Also another issue, when I stream my HyperX cloud 2 headset makes a weird popping sound every so ofter, which is really annoying and I don't know why, but it only happens when I stream.
set it to 30 fps in obs and enable vsync
you cant steram well without vsync
If you mean to enable vsync in game and cap my frames at 60 then no thanks because I am using 144 hz monitor and I need the fps for smooth gameplay as I am a competetive player and vsync creates input lag + lower fps
