Question / Help Need help with setting up OBS
somerandomguy
I used automatic setup and it works pretty much perfectly besides the ocassional stutter (you can see that here: https://www.youtube.com/watch?v=QNwHy6NtylY). Sorry about the music, I'm pretty wasted. Anyway I have no idea what to tweak to make that go away. I'm also recording display not game capture because that makes stutter like insane.
I should also note that I'm running this game only on 30fps while recording at 60. I tried recording game capture with both 30fps and 60 and the stutter was insane.
My setup:
i7 4790 (boost mode)
GTX 970 (overclocked)
16gbs of RAM
game is not installed on SSD but on HDD
My internet connection is: 60 download and 20 upload.
I'm sorry if this the wrong subforum to post it in. Also I'm using the latest OBS.
14:10:02.068: CPU Name: Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz
14:10:02.068: CPU Speed: 3592MHz
14:10:02.068: Physical Cores: 4, Logical Cores: 8
14:10:02.068: Physical Memory: 16321MB Total, 4649MB Free
14:10:02.068: Windows Version: 10.0 Build 14393 (revision: 1198; 64-bit)
14:10:02.068: Running as administrator: false
14:10:02.068: Aero is Enabled (Aero is always on for windows 8 and above)
14:10:02.069: Portable mode: false
14:10:02.078: OBS 19.0.3 (64bit, windows)
14:10:02.078: ---------------------------------
14:10:02.078: audio settings reset:
14:10:02.078: samples per sec: 44100
14:10:02.078: speakers: 2
14:10:02.080: ---------------------------------
14:10:02.080: Initializing D3D11...
14:10:02.080: Available Video Adapters:
14:10:02.081: Adapter 1: NVIDIA GeForce GTX 970
14:10:02.081: Dedicated VRAM: 4256628736
14:10:02.081: Shared VRAM: 4261961728
14:10:02.081: output 1: pos={0, 0}, size={1920, 1080}, attached=true
14:10:02.082: Loading up D3D11 on adapter NVIDIA GeForce GTX 970 (0)
14:10:02.664: D3D11 loaded successfully, feature level used: 45056
14:10:03.361: ---------------------------------
14:10:03.361: video settings reset:
14:10:03.361: base resolution: 1920x1080
14:10:03.361: output resolution: 1920x1080
14:10:03.361: downscale filter: Bicubic
14:10:03.361: fps: 60/1
14:10:03.361: format: NV12
14:10:03.363: Audio monitoring device:
14:10:03.363: name: Default
14:10:03.363: id: default
14:10:03.363: ---------------------------------
14:10:03.364: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
14:10:03.365: Failed to load 'sl-SI' text for module: 'coreaudio-encoder.dll'
14:10:03.365: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
14:10:03.365: Failed to load 'sl-SI' text for module: 'enc-amf.dll'
14:10:03.366: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
14:10:03.366: Failed to initialize module 'enc-amf.dll'
14:10:03.367: Failed to load 'sl-SI' text for module: 'frontend-tools.dll'
14:10:03.373: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
14:10:03.373: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
14:10:03.374: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
14:10:03.374: Failed to load 'en-US' text for module: 'obs-browser.dll'
14:10:03.374: [browser_source: 'Version: 1.29.0']
14:10:03.377: NVENC supported
14:10:03.378: Failed to load 'sl-SI' text for module: 'obs-qsv11.dll'
14:10:03.407: Failed to load 'sl-SI' text for module: 'obs-text.dll'
14:10:03.408: Failed to load 'sl-SI' text for module: 'obs-transitions.dll'
14:10:03.409: Failed to load 'sl-SI' text for module: 'obs-vst.dll'
14:10:03.412: Failed to load 'sl-SI' text for module: 'vlc-video.dll'
14:10:03.412: Couldn't find VLC installation, VLC video source disabled
14:10:03.416: No blackmagic support
14:10:03.420: Failed to load 'sl-SI' text for module: 'win-mf.dll'
14:10:03.621: ---------------------------------
14:10:03.621: Loaded Modules:
14:10:03.621: win-wasapi.dll
14:10:03.621: win-mf.dll
14:10:03.621: win-dshow.dll
14:10:03.621: win-decklink.dll
14:10:03.621: win-capture.dll
14:10:03.621: vlc-video.dll
14:10:03.621: text-freetype2.dll
14:10:03.621: rtmp-services.dll
14:10:03.621: obs-x264.dll
14:10:03.621: obs-vst.dll
14:10:03.621: obs-transitions.dll
14:10:03.621: obs-text.dll
14:10:03.621: obs-qsv11.dll
14:10:03.621: obs-outputs.dll
14:10:03.621: obs-filters.dll
14:10:03.621: obs-ffmpeg.dll
14:10:03.621: obs-browser.dll
14:10:03.621: image-source.dll
14:10:03.621: frontend-tools.dll
14:10:03.621: enc-amf.dll
14:10:03.621: coreaudio-encoder.dll
14:10:03.621: ==== Startup complete ===============================================
14:10:03.622: All scene data cleared
14:10:03.622: ------------------------------------------------
14:10:03.655: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
14:10:03.657: [WASAPISource::WASAPISource] Device 'default' not found. Waiting for device
14:10:03.683: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
14:10:07.682: Switched to scene 'Scena'
14:10:07.684: ------------------------------------------------
14:10:07.684: Loaded scenes:
14:10:07.684: - scene 'Scena':
14:10:07.684: - source: 'Game Capture' (game_capture)
14:10:07.684: - source: 'Game Capture 2' (game_capture)
14:10:07.684: - source: 'Display Capture' (monitor_capture)
14:12:12.901: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
14:14:21.774: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
EDIT: It didn't allow me to edit the previous post because of some spam warning so I double posted. My bad if it breaks the rules.
Remove the second game capture source and remove the display capture source.
If your game is running at 30fps, you are better off streaming or recording at 30fps as well.
