Hello there! I'm new to the forums so please forgive me if I'm posting this in the wrong section.
For the past week or so I have been trying to get good quality on my stream, but I seem to be missing something because the quality isn't there. I tried using the recommended x264 presets veryfast, faster, fast, medium, and even slow with 6000-8000 kb. I even did what most Fortnite streamers do and set my output resolution to 900p but the quality is nowhere near as crisp as theirs. Am I missing something? I also can't stream using the presets because my CPU usage skyrockets to 70% just by moving around in-game.
This happens with Faster-Slow presets. I had to resort to using custom x264 settings, which I will provide down below, to stream a somewhat decent looking stream. The video doesn't even look 60fps and my CPU usage is nowhere near 100%. It stays somewhere between 20-50% depending on what x264 options I use. That's while playing a game like "Metro Exodus". I understand that the more there is to encode and compress the worse the quality of the video/stream will be. What can I do to improve my stream quality and what are the others doing that I am not?
Trying to get good 1080p 60fps stream quality
x264 custom settings:
8x8dct=1 aq-mode=2 bframes=1 chroma-qp-offset=2 colormatrix=smpte170m deblock=0:0 direct=auto ipratio=1.41 keyint=240 level=3.1 me=uhm merange=16 min-keyint=auto mixed-refs=1 no-mbtree=0 partitions=i4x4,p8x8,b8x8 psy-rd=0.5:0.0 ratetol=10 rc-lookahead=30 ref=1 scenecut=40 subme=7 threads=0 trellis=2 weightb=1 weightp=2
level=4.2 no-cabac=1 ref=2 bframes=1 b-adapt=1 direct=auto deblock=-3:2 me=uhm merange=20 subme=6 no-mbtree=1 trellis=0 weightp=1 deadzone-intra=6 deadzone-inter=18 rc-lookahead=0 threads=6 lookahead_threads=0 sliced_threads=0 **** The one I use to Stream action type games ****
Log File: https://obsproject.com/logs/kxp8mh0LcBvFG85N
Games currently being playing
Paladins (PC)
Burning Soul Worker
Metro Exodus
Onigiri
Fortnite
PC Specs
CPU : AMD Ryzen 7 3700x
GPU : AMD RX 580 GTS Black Edition 8GB
RAM: 16GB of 3200mhz G.Skill Ripjaws
Platform: Windows 10 Pro 64bit
Screen Shots: Don't mind the Placebo preset as the x264 options completely ignore any preset I select. Tried and tested myself and there were no noticeable changes in anything.
Paladins (PC)
Burning Soul Worker
Metro Exodus
Onigiri
Fortnite
PC Specs
