Question / Help Need help with OBS Studio settings | I lag when playing games
VinnyX
So I like to stream and sometimes my stream goes very well and other times the game fps can be over a hundred and justs goes to 90 then 50ish then back to 150+ it kills the gameplay for me.
SPECS
OS Name    Microsoft Windows 10 Pro
Version    10.0.15063 Build 15063
Other OS Description     Not Available
OS Manufacturer    Microsoft Corporation
System Type    x64-based PC
System SKU    To Be Filled By O.E.M.
Processor    Intel(R) Core(TM) i5-4460  CPU @ 3.20GHz, 3201 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date    American Megatrends Inc. P1.60, 6/13/2016
SMBIOS Version    2.8
Embedded Controller Version    255.255
BIOS Mode    Legacy
BaseBoard Manufacturer    ASRock
BaseBoard Model    Not Available
BaseBoard Name    Base Board
Platform Role    Desktop
Secure Boot State    Unsupported
PCR7 Configuration    Binding Not Possible
Windows Directory    C:\Windows
System Directory    C:\Windows\system32
Boot Device    \Device\HarddiskVolume1
Locale    United States
Hardware Abstraction Layer    Version = "10.0.15063.502"
Time Zone    Eastern Daylight Time
Installed Physical Memory (RAM)    8.00 GB
Total Physical Memory    7.95 GB
Available Physical Memory    881 MB
Total Virtual Memory    12.0 GB
Available Virtual Memory    3.65 GB
Page File Space    4.00 GB
Page File    C:\pagefile.sys
Device Encryption Support    Reasons for failed automatic device encryption: TPM is not usable, PCR7 binding is not supported, Hardware Security Test Interface failed and device is not InstantGo, Un-allowed DMA capable bus/device(s) detected, TPM is not usable
Hyper-V - VM Monitor Mode Extensions    Yes
Hyper-V - Second Level Address Translation Extensions    Yes
Hyper-V - Virtualization Enabled in Firmware    Yes
Hyper-V - Data Execution Protection    Yes
More Info:
I run two monitors both plugged into GPU and are 1920x1080 as well as 60hz.
Upload:
6.00 Mbps
Games:
CS:GO, Rocket League, PUBG, and Rainbow Six Seige
Last log:
https://gist.github.com/4ceb2595644054b67a88fa68aaed7855
If there's anyway you guys can help me out by figuring out my twitch settings that'd be greatly appreciated.
