Question / Help Need help with OBS Studio settings for Laptop (laggy) with log
ebbs
i recently bought an elgato hd60 and want to start streaming. i looked up and tried several different settings for lower end pcs, but it always ends up being unwatchable and laggy and the delay between webcam and gameplay gradually increases.
the cpu usage with obs is usually around 70%.
these are my specs: i7-6500U 2.50ghz
8GB RAM
Geforce 940m
what settings can i stream on? (I am streaming Xbox One gameplay)
heres my log:
13:38:18.977: CPU Name: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
13:38:18.977: CPU Speed: 2592MHz
13:38:18.977: Physical Cores: 2, Logical Cores: 4
13:38:18.977: Physical Memory: 8090MB Total, 4153MB Free
13:38:18.978: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
13:38:18.978: Running as administrator: false
13:38:18.978: Aero is Enabled (Aero is always on for windows 8 and above)
13:38:18.978: Portable mode: false
13:38:19.000: OBS 17.0.2 (64bit, windows)
13:38:19.000: ---------------------------------
13:38:19.000: audio settings reset:
13:38:19.000: samples per sec: 44100
13:38:19.000: speakers: 2
13:38:19.001: ---------------------------------
13:38:19.001: Initializing D3D11..
13:38:19.001: Available Video Adapters:
13:38:19.005: Adapter 1: Intel(R) HD Graphics 520
13:38:19.005: Dedicated VRAM: 134217728
13:38:19.005: Shared VRAM: 4241702912
13:38:19.005: output 1: pos={0, 0}, size={1920, 1080}, attached=true
13:38:19.005: Adapter 2: NVIDIA GeForce 940M
13:38:19.005: Dedicated VRAM: 2117992448
13:38:19.008: Loading up D3D11 on adapter Intel(R) HD Graphics 520 (0)
13:38:19.015: D3D11 loaded sucessfully, feature level used: 45056
13:38:19.579: ---------------------------------
13:38:19.579: video settings reset:
13:38:19.579: base resolution: 1280x720
13:38:19.579: output resolution: 960x540
13:38:19.579: downscale filter: Bilinear
13:38:19.579: fps: 30/1
13:38:19.579: format: NV12
13:38:19.581: ---------------------------------
13:38:19.585: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
13:38:19.594: [CoreAudio encoder]: Adding CoreAudio AAC encoder
13:38:19.597: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
13:38:19.609: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
13:38:19.609: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
13:38:19.610: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
13:38:19.611: Failed to load 'en-US' text for module: 'obs-browser.dll'
13:38:19.611: [browser_source: 'Version: 1.27.0']
13:38:19.613: NVENC supported
13:38:19.637: VLC found, VLC video source enabled
13:38:19.644: No blackmagic support
13:38:19.893: ---------------------------------
13:38:19.893: Loaded Modules:
13:38:19.893: win-wasapi.dll
13:38:19.893: win-mf.dll
13:38:19.893: win-dshow.dll
13:38:19.893: win-decklink.dll
13:38:19.893: win-capture.dll
13:38:19.893: vlc-video.dll
13:38:19.893: text-freetype2.dll
13:38:19.893: rtmp-services.dll
13:38:19.893: obs-x264.dll
13:38:19.893: obs-transitions.dll
13:38:19.893: obs-text.dll
13:38:19.893: obs-qsv11.dll
13:38:19.893: obs-outputs.dll
13:38:19.893: obs-filters.dll
13:38:19.893: obs-ffmpeg.dll
13:38:19.893: obs-browser.dll
13:38:19.893: image-source.dll
13:38:19.893: frontend-tools.dll
13:38:19.893: enc-amf.dll
13:38:19.893: coreaudio-encoder.dll
13:38:19.893: ==== Startup complete ===============================================
13:38:19.902: All scene data cleared
13:38:19.902: ------------------------------------------------
13:38:19.927: WASAPI: Device 'Lautsprecher (Realtek High Definition Audio)' initialized
13:38:19.928: [WASAPISource::TryInitialize]:[Mic in at front panel (black) (Realtek High Definition Audio)] Failed to activate client context: 88890004
13:38:19.928: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{5766793b-657c-46a2-9e46-a2d4b20b6904}' not found. Waiting for device
13:38:19.932: Videoaufnahmegerät: DecodeDeviceId failed
13:38:19.932: Videoaufnahmegerät: Video configuration failed
13:38:19.936: WASAPI: Device 'Mikrofonarray (Realtek High Definition Audio)' initialized
13:38:20.058: Switched to scene 'Szene'
13:38:20.060: ------------------------------------------------
13:38:20.060: Loaded scenes:
13:38:20.060: - scene 'Szene':
13:38:20.061: - source: 'elgato' (dshow_input)
13:38:20.061: - source: 'cam' (dshow_input)
13:38:20.061: - filter: 'Videoverzögerung (Asynchron)' (async_delay_filter)
13:38:20.061: - filter: 'Schärfen' (sharpness_filter)
13:38:20.061: - source: 'BrowserSource' (browser_source)
13:38:20.061: - source: 'Audio Eingabe Aufnahme' (wasapi_input_capture)
13:38:20.061: - source: 'Bild 1' (image_source)
13:38:20.061: - source: 'boxx' (browser_source)
13:38:20.061: - source: 'Videoaufnahmegerät' (dshow_input)
13:38:20.061: ------------------------------------------------
13:38:20.526: Update check: last known remote version is 17.0.2
13:38:20.568: ---------------------------------
13:38:20.568: [DShow Device: 'cam'] settings updated:
13:38:20.568: video device: HP Truevision HD
13:38:20.568: video path: \\?\usb#vid_05c8&pid_0379&mi_00#6&ffd9722&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
13:38:20.568: resolution: 640x480
13:38:20.568: fps: 30.00 (interval: 333333)
13:38:20.568: format: YUY2
13:38:20.853: A sprite cannot be drawn without a width/height
13:38:20.885: A sprite cannot be drawn without a width/height
13:38:20.941: A sprite cannot be drawn without a width/height
13:38:20.951: A sprite cannot be drawn without a width/height
13:38:20.985: A sprite cannot be drawn without a width/height
13:38:21.018: A sprite cannot be drawn without a width/height
13:38:21.052: A sprite cannot be drawn without a width/height
13:38:21.085: A sprite cannot be drawn without a width/height
13:38:21.119: A sprite cannot be drawn without a width/height
13:38:21.153: A sprite cannot be drawn without a width/height
13:38:21.185: A sprite cannot be drawn without a width/height
13:38:21.225: A sprite cannot be drawn without a width/height
13:38:21.253: A sprite cannot be drawn without a width/height
13:38:21.285: A sprite cannot be drawn without a width/height
13:38:21.318: A sprite cannot be drawn without a width/height
13:38:21.351: A sprite cannot be drawn without a width/height
13:38:26.351: ---------------------------------
13:38:26.351: [DShow Device: 'elgato'] settings updated:
13:38:26.351: video device: Elgato Game Capture HD
13:38:26.351: video path: __elgato
13:38:26.351: resolution: 1920x1080
13:38:26.351: fps: 60.00 (interval: 166666)
13:38:26.351: format: UYVY
13:38:26.351: using video device audio: yes
13:38:26.351: sample rate: 48000
13:38:26.351: channels: 2
13:38:26.351: audio type: Capture
13:38:32.420: adding 23 milliseconds of audio buffering, total audio buffering is now 23 milliseconds
13:38:38.287: ---------------------------------
13:38:38.288: [x264 encoder: 'streaming_h264'] preset: veryfast
13:38:38.288: [x264 encoder: 'streaming_h264'] settings:
13:38:38.288: rate_control: CBR
13:38:38.288: bitrate: 2500
13:38:38.288: buffer size: 2500
13:38:38.288: crf: 0
13:38:38.288: fps_num: 30
13:38:38.288: fps_den: 1
13:38:38.288: width: 1280
13:38:38.288: height: 720
13:38:38.288: keyint: 60
13:38:38.288: vfr: off
13:38:38.288:
13:38:38.288: [x264 encoder: 'streaming_h264'] custom settings: scenecut=0
13:38:38.300: [CoreAudio AAC: 'Track1']: settings:
13:38:38.300: mode: AAC
13:38:38.300: bitrate: 96
13:38:38.300: sample rate: 44100
13:38:38.300: cbr: on
13:38:38.300: output buffer: 1536
13:38:38.305: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-fra.twitch.tv/app...
13:38:38.340: [rtmp stream: 'adv_stream'] Interface: Intel(R) Dual Band Wireless-AC 7265 (802.11, 144 mbps)
13:38:40.007: [rtmp stream: 'adv_stream'] Connection to rtmp://live-fra.twitch.tv/app successful
13:38:40.013: ==== Streaming Start ===============================================
13:40:26.272: adding 23 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
13:40:26.472: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
13:40:28.991: adding 23 milliseconds of audio buffering, total audio buffering is now 92 milliseconds
13:40:30.896: adding 46 milliseconds of audio buffering, total audio buffering is now 139 milliseconds
13:40:31.065: adding 23 milliseconds of audio buffering, total audio buffering is now 162 milliseconds
13:40:36.977: adding 23 milliseconds of audio buffering, total audio buffering is now 185 milliseconds
13:40:37.181: adding 23 milliseconds of audio buffering, total audio buffering is now 208 milliseconds
13:40:46.870: adding 23 milliseconds of audio buffering, total audio buffering is now 232 milliseconds
13:40:46.940: adding 23 milliseconds of audio buffering, total audio buffering is now 255 milliseconds
13:40:47.030: adding 23 milliseconds of audio buffering, total audio buffering is now 278 milliseconds
13:40:47.064: adding 23 milliseconds of audio buffering, total audio buffering is now 301 milliseconds
13:40:47.189: adding 46 milliseconds of audio buffering, total audio buffering is now 348 milliseconds
13:40:47.298: adding 46 milliseconds of audio buffering, total audio buffering is now 394 milliseconds
13:40:47.345: adding 23 milliseconds of audio buffering, total audio buffering is now 417 milliseconds
13:41:39.992: adding 255 milliseconds of audio buffering, total audio buffering is now 673 milliseconds
13:41:45.990: adding 255 milliseconds of audio buffering, total audio buffering is now 928 milliseconds
13:41:50.728: [rtmp stream: 'adv_stream'] User stopped the stream
13:41:50.728: Output 'adv_stream': stopping
13:41:50.728: Output 'adv_stream': Total encoded frames: 4912
13:41:50.728: Output 'adv_stream': Total drawn frames: 5773
13:41:50.728: Output 'adv_stream': Number of skipped frames due to encoding lag: 5427 (110.5%)
13:41:50.728: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 972 (16.8%)
13:41:50.728: Output 'adv_stream': Number of dropped frames due to insufficient bandwidth/connection stalls: 8 (0.2%)
13:41:50.732: ==== Streaming Stop ================================================
13:42:04.108: Max audio buffering reached!
13:42:04.109: adding 116 milliseconds of audio buffering, total audio buffering is now 1044 milliseconds
