Question / Help Need help with Blade Runner (1997)
Walter937
I've been trying to stream this game for a while now, in the old OBS it didn't even recognize the game, and now with OBS studio it regcognize it on the game capture tab, however it does not capture it, not even with hotkeys application selector, however it's somewhat visible when I put capture screen, this, however, makes it look like a little square in the top left corner of the screen.
If anyone know how can I make this work some support would be appreciated
It sounds like you have forgotten to scale the image in the preview screen to fill the preview screen?
If not the case, not sure what could be the issue.
Forgot to mention, Blade Runner was awesome!
Walter937
I tried this, changing my monitor resolution to 800x600 and changing the stream resolution to 640x480 it worked, kind of, at least the video is fullscreen, however, it freezes every 2 seconds and then it unfreezes and so on.
Can you do a stream session for at least a few minutes please, then upload the logfile for that stream session. Will be able to help a lot more with troubleshooting.
In OBS Studio, if you click on the Help tab at the top, then hover over the Log Files context menu, you can upload the current or last logfile. It will take a few moments for a window to open up over OBS Studio, copy that link and in the edit box for posting a message/reply there is a chain-link symbol (7th from the left) Click on that symbol and paste the link you copied into that URL box, click on insert and it will paste the link in the correct format for you in the edit box.
Just remember to do a stream/recording attempt for a few minutes (Whilst doing what you would normally do when streaming/recording) so it provides enough time and frames captured to give a good indication of system performance. Be sure to stop the streaming/recording attempt before you upload the current logfile too!
Note: Everybody starts from a beginning.
@Tom Britton, still awaiting an uploaded logfile from @Walter937 in regards to his issue and his particular PC setup + OBS settings. You could post a logfile if you like, will try to lend a hand and hopefully sparks Walter to upload a logfile with a stream attempt for his issue (If it still is an issue)
