Emilia2545
*Log file down THERE*
- Currently I'm getting quite invested into Valorant (Riot Games). Getting invested has taken up quite a bit of my time....Whether I'm aim training or watching videos just trying to get MORE educated for..obviously..being the best. The problem I run into here is I Valorant does not have a replay system, so you can't watch your previous games. Trying to watch my previous games by recording them, and if I'm going to do that I thought "Why not stream instead?". Now I've ended up HERE
- When I try to record my frames drop obviously, and along with that the recording freezing every 2 - 5 seconds or it just looks like I'm getting no frames. I tried turning the bitrate up, lowering my resolutions, and even lowering the framerate that Valorant is being recorded in. Still no solution...I also used the auto configuration wizard, and that was no help at all.
- All I'm asking for is to be able to record/stream in 60 FPS, at 720p(480p at least), and also be able to play Valorant with a MINIMUM of 180-200 FPS. I run Valorant in 1152x864 4:3 (stretched), and all of my graphics are as low as can be. If not doable then that's fine, but if so that'd be great. I will make whatever changes necessary for my PC
