Deywark
Hi, I have been experiencing audio distorsions for a while (Both recording and streaming) and I want to fix it because i got tired of it. *I have all my audios channels split into different tracks by using a plugin right now, but I also tested using the Application Audio Capture (Beta) option from obs.*
Here you have a Distorsion Sample: https://youtu.be/eQeI_mGY9Z8
And Logs : Obs Analyzer link and pastebin
Things I already tried:
This problem occurs once per live or recording, usually it happens for not more than 10 seconds, and restores to normality, but as you can tell by the sample, sometimes I'm recording games, and i need to cut everyting that happens in that time frame.
My pc specs:
Ryzen 7 5800x (3.80 GHz - No OC)
RTX 3060 ti (546.01)
DDR4 RAM 2x8 3000mhz (HyperX Fury Renegade) CL15
Windows 11 23H2
OBS 30.0.0
If you need further information, i'm glad to help.
- Disabling unused devices on windows.
- Matching sample rates
- Running as admin
- Reinstall windows 11
- Change to prior obs versions
- Both capturing the audio with an external obs plugin and the native way
My pc specs:
Windows 11 23H2
OBS 30.0.0
