Question / Help Need help setting up OBS
Kiandee
I want to setup a stream for LoL but I want to make it as clear and nice looking as much as possible on my pc.
My specs are:
AMD FX 4300 Quad Core 3.80GHz
8 GB RAM
64-bit operating, x64 based processor
Windows 8.1
EVGA GeForce GTX 960 SuperSC ACX 2.0+ 2GB 128bit
Perhaps change your title to attract fellow LoL streamers? Ask what settings they use and compare their gear to yours. I can tell you a lot is going to depend on your CPU.
You can always try thins out yourself using a local recording. See how it affects your framerate, see if you like the resulting file.
