Question / Help Need help setting up OBS streams settings...
KeithTreason
I've had OBS for awhile and after continuously trying to get working settings, I've gotten nowhere so here I am asking for help from those that are willing to give it. I've messed with the bitrate,buffer size, CPU Usage, Output resolution, FPS, etc. etc.
What I am trying to do:
∆ - Stream myself working in programs like Premiere Pro, After Effects, and C4D to YouTube.
Problems:
∆ - Low internet speeds
∆ - Large screen size
∆ - Audio syncing issues
Specks:
∆ - Internet speed (It sucks, I live out in the country and it was slower than usual today)
∆ - Log from speedtest.net
- download speed 4.5 MBs
- upload speed 2.9 MBs
- PNG 11 ms
∆ - Computer
- iMac running OSX Yosemite
- 5120 x 2880 (Retina 5K, 27-inch, Late 2014)
- 3.5 GHz Intel Core i5
- 8GB 1600 MHz DDR3
- AMD Radeon R9 M290X 2048 MB
∆ - OBS
- OBS 0.12.0(mac)
LOG
21:54:48.462: CPU Name: Intel(R) Core(TM) i5-4690 CPU @ 3.50GHz
21:54:48.462: CPU Speed: 3500MHz
21:54:48.462: Physical Cores: 4, Logical Cores: 4
21:54:48.462: Physical Memory: 8192MB Total
21:54:48.462: OS Name: Mac OS X (NSMACHOperatingSystem)
21:54:48.462: OS Version: Version 10.10 (Build 14A389)
21:54:48.462: Kernel Version: 14.0.0
21:54:48.477: hotkeys-cocoa: Using layout 'com.apple.keylayout.US'
21:54:48.540: OBS 0.12.0 (mac)
21:54:48.540: ---------------------------------
21:54:48.541: ---------------------------------
21:54:48.541: audio settings reset:
21:54:48.541: samples per sec: 44100
21:54:48.541: speakers: 1
21:54:48.541: buffering (ms): 1000
21:54:48.684: ---------------------------------
21:54:48.684: video settings reset:
21:54:48.684: base resolution: 5120x2880
21:54:48.684: output resolution: 1860x1046
21:54:48.684: fps: 30/1
21:54:48.684: format: NV12
21:54:48.686: ---------------------------------
21:54:48.688: Loading module: coreaudio-encoder.so
21:54:48.689: ---------------------------------
21:54:48.691: Loading module: image-source.so
21:54:48.692: ---------------------------------
21:54:48.694: Loading module: mac-avcapture.so
21:54:48.695: ---------------------------------
21:54:48.697: Loading module: mac-capture.so
21:54:48.698: ---------------------------------
21:54:48.700: Loading module: mac-decklink.so
21:54:48.702: No blackmagic support
21:54:48.702: Failed to start search for DeckLink devices
21:54:48.702: ---------------------------------
21:54:48.710: Loading module: mac-syphon.so
21:54:48.711: ---------------------------------
21:54:48.713: Loading module: mac-vth264.so
21:54:48.737: [VideoToolbox encoder]: Adding VideoToolbox H264 encoders
21:54:48.737: ---------------------------------
21:54:48.739: Loading module: obs-ffmpeg.so
21:54:48.741: ---------------------------------
21:54:48.743: Loading module: obs-filters.so
21:54:48.744: ---------------------------------
21:54:48.746: Loading module: obs-outputs.so
21:54:48.748: ---------------------------------
21:54:48.749: Loading module: obs-x264.so
21:54:48.750: ---------------------------------
21:54:48.753: Loading module: rtmp-services.so
21:54:48.754: ---------------------------------
21:54:48.757: Loading module: text-freetype2.so
21:54:50.177: =====================================================================
21:54:50.177: output 'simple_stream' (rtmp_output) created
21:54:50.177: encoder 'simple_h264_stream' (obs_x264) created
21:54:50.283: AAC encoder bitrate mapping:
21:54:50.283: 20 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 24 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 28 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 32 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 40 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 48 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 56 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 64 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 72 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 80 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 96 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 112 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 128 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 144 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 160 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 192 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 224 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 256 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 288 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: 320 kbit/s: 'CoreAudio AAC encoder' (CoreAudio_AAC)
21:54:50.283: encoder 'simple_aac' (CoreAudio_AAC) created
21:54:50.284: output 'simple_file_output' (ffmpeg_muxer) created
21:54:50.284: service 'default_service' (rtmp_common) created
21:54:50.285: All scene data cleared
21:54:50.285: ------------------------------------------------
21:54:50.345: coreaudio: device 'Soundflower (2ch)' initialized
21:54:50.345: source 'Desktop Audio' (coreaudio_output_capture) created
21:54:50.348: coreaudio: device 'Movavi Sound Grabber' initialized
21:54:50.348: source 'Mic/Aux' (coreaudio_input_capture) created
21:54:50.694: coreaudio: device 'Movavi Sound Grabber' initialized
21:54:50.694: source 'Mic/Aux 2' (coreaudio_input_capture) created
21:54:50.698: coreaudio: device 'Movavi Sound Grabber' initialized
21:54:50.698: source 'Mic/Aux 3' (coreaudio_input_capture) created
21:54:50.698: source 'Scene' (scene) created
21:54:50.741: Audio line 'Mic/Aux 3' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
21:54:50.741: Audio line 'Mic/Aux 2' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
21:54:50.741: Audio line 'Mic/Aux' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
21:54:50.741: Audio line 'Desktop Audio' audio data currently getting cut off. This could be due to a negative sync offset that's larger than the current audio buffering time.
21:54:50.767: Audio line 'Mic/Aux 3' audio data no longer getting cut off.
21:54:50.767: Audio line 'Mic/Aux 2' audio data no longer getting cut off.
21:54:50.767: Audio line 'Mic/Aux' audio data no longer getting cut off.
21:54:50.767: Audio line 'Desktop Audio' audio data no longer getting cut off.
21:54:50.913: source 'Display Capture' (display_capture) created
21:54:50.917: coreaudio: device 'Built-in Microphone' initialized
21:54:50.917: source 'Audio Input Capture' (coreaudio_input_capture) created
21:54:50.917: source 'Scene 1' (scene) created
21:54:50.928: source 'Display Capture 1' (display_capture) created
21:54:51.425: coreaudio: device 'Built-in Microphone' initialized
21:54:51.425: source 'Audio Input Capture 1' (coreaudio_input_capture) created
21:54:51.592: == Profiler Results =============================
21:54:51.592: run_program_init: 3832.71 ms
21:54:51.592: ┣OBSApp::AppInit: 9.343 ms
21:54:51.592: ┃ ┗OBSApp::InitLocale: 1.895 ms
21:54:51.592: ┗OBSApp::OBSInit: 3448.72 ms
21:54:51.592: ┣obs_startup: 16.076 ms
21:54:51.592: ┗OBSBasic::OBSInit: 3051.63 ms
21:54:51.592: ┣OBSBasic::InitBasicConfig: 0.541 ms
21:54:51.592: ┣OBSBasic::ResetAudio: 0.372 ms
21:54:51.592: ┣OBSBasic::ResetVideo: 142.568 ms
21:54:51.592: ┣OBSBasic::InitOBSCallbacks: 0.009 ms
21:54:51.592: ┣OBSBasic::InitHotkeys: 0.398 ms
21:54:51.592: ┣obs_load_all_modules: 1492.08 ms
21:54:51.592: ┃ ┣obs_init_module(coreaudio-encoder.so): 0.237 ms
21:54:51.592: ┃ ┣obs_init_module(image-source.so): 0.003 ms
21:54:51.592: ┃ ┣obs_init_module(mac-avcapture.so): 0.004 ms
21:54:51.592: ┃ ┣obs_init_module(mac-capture.so): 0.006 ms
21:54:51.592: ┃ ┣obs_init_module(mac-decklink.so): 0.097 ms
21:54:51.592: ┃ ┣obs_init_module(mac-syphon.so): 0.008 ms
21:54:51.592: ┃ ┣obs_init_module(mac-vth264.so): 23.436 ms
21:54:51.592: ┃ ┣obs_init_module(obs-ffmpeg.so): 0.845 ms
21:54:51.592: ┃ ┣obs_init_module(obs-filters.so): 0.005 ms
21:54:51.592: ┃ ┣obs_init_module(obs-outputs.so): 0.006 ms
21:54:51.592: ┃ ┣obs_init_module(obs-x264.so): 0.004 ms
21:54:51.592: ┃ ┣obs_init_module(rtmp-services.so): 0.368 ms
21:54:51.592: ┃ ┗obs_init_module(text-freetype2.so): 1419.48 ms
21:54:51.592: ┣OBSBasic::ResetOutputs: 106.763 ms
21:54:51.592: ┣OBSBasic::CreateHotkeys: 0.028 ms
21:54:51.592: ┣OBSBasic::InitService: 0.434 ms
21:54:51.592: ┣OBSBasic::InitPrimitives: 0.094 ms
21:54:51.592: ┗OBSBasic::Load: 1149.32 ms
21:54:51.592: =================================================
21:54:53.805: [rtmp-services plugin] Remote update of URL "https://obsproject.com/obs2_update/rtmp-services/package.json" failed: Server aborted the SSL handshake
21:55:56.588: service 'default_service' (rtmp_common) created
21:55:56.588: service 'default_service' destroyed
21:55:56.591: Settings changed (stream 1)
21:55:56.591: ------------------------------------------------
21:56:04.803: ---------------------------------
21:56:04.803: [x264 encoder: 'simple_h264_stream'] preset: superfast
21:56:04.803: [x264 encoder: 'simple_h264_stream'] profile: main
21:56:04.804: [x264 encoder: 'simple_h264_stream'] settings:
21:56:04.804: bitrate: 2000
21:56:04.804: buffer size: 2000
21:56:04.804: crf: 0 (0 when CBR is enabled)
21:56:04.804: fps_num: 30
21:56:04.804: fps_den: 1
21:56:04.804: width: 1860
21:56:04.804: height: 1046
21:56:04.804: keyint: 120
21:56:04.804: vfr: off
21:56:04.804: cbr: on
21:56:04.834: [CoreAudio AAC: 'simple_aac']: settings:
21:56:04.834: mode: AAC
21:56:04.834: bitrate: 160
21:56:04.834: sample rate: 44100
21:56:04.834: cbr: on
21:56:04.834: output buffer: 768
21:56:04.834: [rtmp stream: 'simple_stream'] Connecting to RTMP URL ________...
21:56:05.629: [rtmp stream: 'simple_stream'] Connection to ________
21:56:05.648: ==== Streaming Start ===============================================
21:57:35.141: [rtmp stream: 'simple_stream'] User stopped the stream
21:57:35.188: Output 'simple_stream': stopping
21:57:35.188: Output 'simple_stream': Total frames: 2711
21:57:35.188: Output 'simple_stream': Number of skipped frames: 37 (1.36481%)
21:57:35.188: Output 'simple_stream': Number of dropped frames: 16 (0.590188%)
21:57:35.188: ==== Streaming Stop ================================================
