EEComicsAndGames
First of all, thank you for taking the time to help me out with this. Here is what I want to do, I need help figuring out how to do it.
I would like to host video game tournaments using 2 different Tv's so people can play head to head. I would like to simultaneously stream from both Tv's to one Twitch channel (side by side?) and either stream on Youtube at the same time or upload to Youtube later. At first the tournaments will be run off of two RetroPi (Pi 3b) emulator systems and if all works out more modern system in the future (PS5 etc). To do this I understand I will need: 2x Tv's, 2x Pi's, 2x Capture Cards (recommendations welcome), 1x Computer (built to spec, specs unknown), OBS software.
I understand that the Pi Hooks to the Capture Card and the Capture Card to the TV & the computer.
Will this set up work?
Is there a set of capture cards that will work best for this set up?
Can OBS simultaneously show both Tv in one stream?
16gb Ram, Windows 10, 1tb ssd, seem good enough? (this will be a dedicated PC and do nothing else)
Am I missing anything?
Again, thank you all for helping me plan this out.
