Penguin11112
I need help finding good settings without stream lag, on twitch of course. i am new to OBS so would love help. thanks
07:59:27.074: CPU Name: Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz
07:59:27.074: CPU Speed: 3391MHz
07:59:27.074: Physical Cores: 4, Logical Cores: 8
07:59:27.075: Physical Memory: 12266MB Total, 9524MB Free
07:59:27.075: Windows Version: 10.0 Build 17134 (revision: 165; 64-bit)
07:59:27.075: Running as administrator: false
07:59:27.075: Aero is Enabled (Aero is always on for windows 8 and above)
07:59:27.075: Windows 10 Gaming Features:
07:59:27.075: Game Bar: On
07:59:27.075: Game DVR: On
07:59:27.075: Game DVR Background Recording: Off
07:59:27.076: Sec. Software Status:
07:59:27.078: Windows Defender Antivirus: enabled (AV)
07:59:27.078: Windows Firewall: disabled (FW)
07:59:27.079: Windows Defender Antivirus: enabled (ASW)
07:59:27.079: Portable mode: false
07:59:27.205: OBS 21.1.0 (64bit, windows)
07:59:27.205: ---------------------------------
07:59:27.218: ---------------------------------
07:59:27.218: audio settings reset:
07:59:27.218: samples per sec: 44100
07:59:27.218: speakers: 2
07:59:27.219: ---------------------------------
07:59:27.219: Initializing D3D11...
07:59:27.219: Available Video Adapters:
07:59:27.221: Adapter 1: NVIDIA GeForce GTX 750 Ti
07:59:27.221: Dedicated VRAM: 2115698688
07:59:27.221: Shared VRAM: 2136053760
07:59:27.221: output 1: pos={0, 0}, size={1920, 1080}, attached=true
07:59:27.221: output 2: pos={1920, 53}, size={1280, 1024}, attached=true
07:59:27.221: output 3: pos={-1280, 53}, size={1280, 1024}, attached=true
07:59:27.224: Loading up D3D11 on adapter NVIDIA GeForce GTX 750 Ti (0)
07:59:27.266: D3D11 loaded successfully, feature level used: 45056
07:59:28.142: ---------------------------------
07:59:28.142: video settings reset:
07:59:28.142: base resolution: 1920x1080
07:59:28.142: output resolution: 960x540
07:59:28.142: downscale filter: Bicubic
07:59:28.142: fps: 48/1
07:59:28.142: format: RGBA
07:59:28.142: YUV mode: None
07:59:28.142: GPU conversion not available for format: 6
07:59:28.144: Audio monitoring device:
07:59:28.144: name: Default
07:59:28.144: id: default
07:59:28.144: ---------------------------------
07:59:28.146: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
07:59:28.169: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
07:59:28.276: [AMF] AMF Test failed due to one or more errors.
07:59:28.276: Failed to initialize module 'enc-amf.dll'
07:59:28.355: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
07:59:28.367: LoadLibrary failed for '../../obs-plugins/64bit/libEGL.dll': The specified procedure could not be found.
07:59:28.367: (127)
07:59:28.367: Module '../../obs-plugins/64bit/libEGL.dll' not loaded
07:59:28.368: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
07:59:28.386: [browser_source: 'Version: 1.31.0']
07:59:28.434: NVENC supported
07:59:28.577: Failed to load 'en-US' text for module: 'obs-ndi.dll'
07:59:28.577: [obs-ndi] hello ! (version 4.4.0)
07:59:28.577: [obs-ndi] Trying 'C:\Program Files\NewTek\NewTek NDI 3.5 Redist\v3'
07:59:28.577: [obs-ndi] Found NDI library at 'C:/Program Files/NewTek/NewTek NDI 3.5 Redist/v3/Processing.NDI.Lib.x64.dll'
07:59:28.829: [obs-ndi] NDI runtime loaded successfully
07:59:28.833: [obs-ndi] NDI library initialized successfully
07:59:29.068: Couldn't find VLC installation, VLC video source disabled
07:59:29.120: No blackmagic support
07:59:29.186: ---------------------------------
07:59:29.186: Loaded Modules:
07:59:29.186: win-wasapi.dll
07:59:29.186: win-mf.dll
07:59:29.186: win-dshow.dll
07:59:29.186: win-decklink.dll
07:59:29.186: win-capture.dll
07:59:29.186: vlc-video.dll
07:59:29.186: text-freetype2.dll
07:59:29.186: rtmp-services.dll
07:59:29.186: obs-x264.dll
07:59:29.186: obs-vst.dll
07:59:29.186: obs-transitions.dll
07:59:29.186: obs-text.dll
07:59:29.186: obs-qsv11.dll
07:59:29.186: obs-outputs.dll
07:59:29.186: obs-ndi.dll
07:59:29.186: obs-filters.dll
07:59:29.186: obs-ffmpeg.dll
07:59:29.186: obs-browser.dll
07:59:29.186: image-source.dll
07:59:29.186: frontend-tools.dll
07:59:29.186: enc-amf.dll
07:59:29.186: coreaudio-encoder.dll
07:59:29.186: ==== Startup complete ===============================================
07:59:29.201: All scene data cleared
07:59:29.201: ------------------------------------------------
07:59:29.307: WASAPI: Device 'Headphones (2- High Definition Audio Device)' initialized
07:59:29.332: WASAPI: Device 'Microphone (2- High Definition Audio Device)' initialized
07:59:29.370: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
07:59:29.571: ---------------------------------
07:59:29.571: [DShow Device: 'Camera'] settings updated:
07:59:29.571: video device: USB Video Device
07:59:29.571: video path: \\?\usb#vid_046d&pid_0809&mi_00#7&848153a&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
07:59:29.571: resolution: 640x480
07:59:29.571: fps: 30.00 (interval: 333333)
07:59:29.571: format: YUY2
07:59:30.697: Switched to scene 'Desktop Stream/Record'
07:59:30.706: ------------------------------------------------
07:59:30.706: Loaded scenes:
07:59:30.706: - scene 'Desktop Stream/Record':
07:59:30.706: - source: 'Display Capture' (monitor_capture)
07:59:30.706: - source: 'Alert Box' (browser_source)
07:59:30.706: - source: 'Chat Box' (browser_source)
07:59:30.706: - scene 'Fortnite Stream/Record':
07:59:30.706: - source: 'Fortnite Game' (game_capture)
07:59:30.706: - source: 'Camera' (dshow_input)
07:59:30.706: - scene 'I will BRB':
07:59:30.706: - source: 'Image' (image_source)
07:59:28.367: (127)
