Question / Help Need advice for best settings and solve problem.
Nqmm
Hi!
LOG: https://gist.github.com/15855eef24acc211e13eb3b9d0eb1416
SETUP:
Have streamed a bit now and have problems that i cant solve myself.
First of all when playing cs:go then my audio after shooting is doubled and have some kind of delay.
Then i would like to know which is best settings for my setup and internet. Have 50Mbps net
Thanks for your time!
Your audio has to do with echo. Do the following:
- Mute the webcam mic in your OBS Mixer
- Click the wheel in the OBS Mixer and for the webcam, set volume to 0, Audio monitoring set to Monitor Only (mute output) and don't have any of the tracks enabled
That should prevent your webcam from picking up any sound and if it does, have it streamed out/recorded
For all other recording devices where the mic is open that shouldn't be recorded, you have to do the same thing.
Also, if you got speakers, televisions on, etc. turn the volume off. You don't want that being picked up by the mic.
