My stream keeps buffering when i stream, then when it resumes my audio voice is distorted in the stream, and sometimes speed up my voice.
Miratodre
Can you guys help me. :( I stream on twitch and i notice when i watch my stream, it keeps on loading then when it resumes my audio is distorted, and sometimes it speed up my voice when it resumes. it keeps on loading then resume, loading then resume. I uninstall Aitum plugin because i thought that it is the culprit, but it still happening.
My stream doesn't Crash when i Unisntall the plugin but here are some of my crashes log. i Hope it helps. (sorry for my bad grammar)
  • Crash 2025-11-20 16-14-36.txt
  • Crash 2025-11-23 00-02-48.txt
  • Crash 2025-11-25 23-41-29.txt
  • Crash 2025-11-27 23-46-32.txt
  • Crash 2025-11-28 00-23-38.txt
  • Crash 2025-11-28 01-45-02.txt
  • Crash 2025-11-28 22-22-40.txt
PaiSand
The crash happens on the vertical canvas plugin. You should check for updates and compatibility between versions of the plugin and OBS. Consult in their page for support on how to properly uninstall it.
Same with any other plugin you may have installed.
A log file from an actual full session is also needed (start, do as you normally do, stop, upload current log file). And if it crashed, reopen OBS and upload previous log file.
Miratodre
Okay sir. Ill try it. thankyousomuch
