Question / Help my recording is laggy and not smooth plz help. Setting below.
kingly161
18:20:19.084: CPU Name: Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
18:20:19.084: CPU Speed: 2712MHz
18:20:19.084: Physical Cores: 4, Logical Cores: 4
18:20:19.084: Physical Memory: 8138MB Total, 3526MB Free
18:20:19.084: Windows Version: 10.0 Build 14393 (revision: 693; 64-bit)
18:20:19.084: Running as administrator: false
18:20:19.084: Aero is Enabled (Aero is always on for windows 8 and above)
18:20:19.084: Portable mode: false
18:20:19.094: OBS 17.0.0 (64bit, windows)
18:20:19.094: ---------------------------------
18:20:19.095: ---------------------------------
18:20:19.095: audio settings reset:
18:20:19.095: samples per sec: 44100
18:20:19.095: speakers: 2
18:20:19.132: ---------------------------------
18:20:19.132: Initializing D3D11..
18:20:19.132: Available Video Adapters:
18:20:19.134: Adapter 1: NVIDIA GeForce GT 730
18:20:19.134: Dedicated VRAM: 2116878336
18:20:19.134: Shared VRAM: 4267081728
18:20:19.134: output 1: pos={0, 0}, size={1920, 1080}, attached=true
18:20:19.134: output 2: pos={337, -1024}, size={1280, 1024}, attached=true
18:20:19.138: Loading up D3D11 on adapter NVIDIA GeForce GT 730 (0)
18:20:19.167: D3D11 loaded sucessfully, feature level used: 45056
18:20:19.660: ---------------------------------
18:20:19.660: video settings reset:
18:20:19.660: base resolution: 1824x1014
18:20:19.660: output resolution: 1216x676
18:20:19.660: downscale filter: Bilinear
18:20:19.660: fps: 60/1
18:20:19.660: format: NV12
18:20:19.661: ---------------------------------
18:20:19.688: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
18:20:19.736: [AMF Encoder] Unable to load 'amfrt64.dll', error code 126.
18:20:20.517: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
18:20:20.553: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
18:20:20.628: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
18:20:20.668: Failed to load 'en-US' text for module: 'obs-browser.dll'
18:20:20.668: [browser_source: 'Version: 1.27.0']
18:20:20.808: NVENC supported
18:20:21.250: Couldn't find VLC installation, VLC video source disabled
18:20:21.319: No blackmagic support
18:20:21.572: ---------------------------------
18:20:21.572: Loaded Modules:
18:20:21.572: win-wasapi.dll
18:20:21.572: win-mf.dll
18:20:21.572: win-dshow.dll
18:20:21.572: win-decklink.dll
18:20:21.572: win-capture.dll
18:20:21.572: vlc-video.dll
18:20:21.572: text-freetype2.dll
18:20:21.572: rtmp-services.dll
18:20:21.572: obs-x264.dll
18:20:21.572: obs-transitions.dll
18:20:21.572: obs-text.dll
18:20:21.572: obs-qsv11.dll
18:20:21.572: obs-outputs.dll
18:20:21.572: obs-filters.dll
18:20:21.572: obs-ffmpeg.dll
18:20:21.572: obs-browser.dll
18:20:21.572: image-source.dll
18:20:21.572: frontend-tools.dll
18:20:21.572: enc-amf.dll
18:20:21.572: coreaudio-encoder.dll
18:20:21.572: ==== Startup complete ===============================================
18:20:21.586: All scene data cleared
18:20:21.586: ------------------------------------------------
18:20:21.601: [WASAPISource::TryInitialize]:[Headset Earphone (Razer Kraken 7.1 Chroma)] Failed to activate client context: 88890004
18:20:21.601: [WASAPISource::WASAPISource] Device '{0.0.0.00000000}.{a1682320-7e00-4782-929c-04cf022577e9}' not found. Waiting for device
18:20:21.601: [WASAPISource::TryInitialize]:[Headset Microphone (Razer Kraken 7.1 Chroma)] Failed to activate client context: 88890004
18:20:21.601: [WASAPISource::WASAPISource] Device '{0.0.1.00000000}.{589cdf79-50fa-4720-ac6d-fa351ead04e9}' not found. Waiting for device
18:20:21.607: Switched to scene 'Scene'
18:20:21.607: ------------------------------------------------
18:20:21.607: Loaded scenes:
18:20:21.607: - scene 'Scene':
18:20:21.607: - source: 'Display Capture' (monitor_capture)
18:20:21.607: - source: 'Window Capture' (window_capture)
18:20:22.054: Update check: last known remote version is 17.0.1
18:22:17.925: Settings changed (outputs)
18:22:17.925: ------------------------------------------------
