Question / Help My level is on auto so the magic search engine didn't help
suchalameo
Hello,
I hit start streaming after playing with some of the settings, maybe i just have to completely reinstall OBS but for learning sake maybe someone can help me.
"STARTING THE OUTPUT FAILED. PLEASE CHECK THE LOG FOR DETAILS. NOTE:..."
Drivers are up-to-date. After hitting "Start Streaming" i get that message and then it doesn't work.
21:25:39.614: Settings changed (outputs)
21:25:39.614: ------------------------------------------------
21:26:16.865: ---------------------------------
21:26:16.865: [NVENC encoder: 'simple_h264_stream'] settings:
21:26:16.865: rate_control: CBR
21:26:16.865: bitrate: 1500
21:26:16.865: cqp: 0
21:26:16.865: keyint: 120
21:26:16.865: preset: hq
21:26:16.865: profile: main
21:26:16.865: level: auto
21:26:16.865: width: 1280
21:26:16.865: height: 720
21:26:16.865: 2-pass: true
21:26:16.865: b-frames: 2
21:26:16.865: GPU: 0
21:26:16.865:
21:26:16.868: [NVENC encoder: 'simple_h264_stream'] Failed to open NVENC codec: Unknown error occurred
21:26:16.868: Stream output type 'rtmp_output' failed to start!
If you'd like to see the whole log here ya go https://gist.github.com/cdb0c31751e3e6070fc1486c8f9d3e8b
oh for future referance to anyone who may read this, you have to go to
settings > output> advanced > and change you encoder to x264/cbr rate control and add a buffer.
it fixed!
