Noioiy
I used to be able to mute my microphone in OBS using the Logitech G Hub software, but I cannot anymore after getting a new PC (Win 11)
On my old PC (Win 10) I used to have all the audio devices disabled in the audio settings, and I added the microphone as an audio input source directly in each scene. I used to be able to use Logitech G Hub software to toggle mute for the microphone, but it doesn't work on my new PC (Win 11) even though all the settings are the same.
I can use G Hub to control other actions in OBS like starting/stopping stream or recording, or toggling a source on or off, so G Hub is communicating with OBS fine. It just can not toggle microphone mute.
One thing I noticed before making this post is that if I go to OBS audio settings and change Mic/Auxiliary Audio settings from Disabled>My microphone, I can actually toggle microphone mute using G Hub, but in this use case, the Mic/Aux audio mixer is active in all the scenes and picking up audio, which I want to avoid in certain scenes.
This was working perfectly fine on my previous Windows 10 pc, but I am having problems on my new Windows 11 pc.
Log file: https://obsproject.com/logs/Z1kjHIpfWexviGmp
