Simply put, how do I get stereo sound?
I am going to be doing some DJ mixes over Facebook Live. Iv done some test runs and it seems that I am only getting mono although I have set the Channel to stereo. I am new to the software and could have missed something key for my desired setup, so ill state every that could help solve the issue.
I am using an Akai EIE Pro soundcard. I have 2 mono Jacks coming out of the of the L+R Outputs on my mixer and going into 1/2 inputs on the soundcard.
In Settings>Advanced I set the audio to my soundcard, so Akai EIE Pro
I have all the "Audio Devices" disabled and "Channels" set to stereo under, Settings>Audio (Not sure if this is the correct way but it is working when I test the audio in the live stream)
I created an "Audio Input Capture" in the "Sources" section and set it to "Line In (Akai EIE Pro Audio)
I have a webcam that has a mic so a channel for it appears in the "Mixer" section. In the "Properties" of the video channel I have "Audio Output Mode" which can be set to "Capture Audio Only" "Output Desktop" or "Output Desktop". Im not sure what to set it too here so I left it on "Capture Audio Only" and ticked the "Use Custom Audio Device" where I selected "Line In (Akai EIE Pro Audio)"
Thats how I have it set up and and get audio fine but it seems to be in mono. Please let me know what you think is the problem.
Thanks
Thanks
