Monitor audio and output audio different volumes
lavenderooze
How do I change my monitor volume to be higher?
My viewers get absolutely blasted if I turn it up more, and I can barely hear a whisper over the other volumes that I've gotten perfect... Is there a way to seperate monitor and output volume?
Suslik V
You may try "Source Clone" or "Asynchronous Source Duplication" plugin with combination of the Gain filters or just Audio Mixer volume sliders (this depends how you adjusted the volume in the first place):
The newly added Source Clone or Asynchronous Source Duplicator source/filter can be excluded from all output tracks but still can be monitored. In some cases these sources make clones of the video image too, so be careful to not blend video twice into output when you need only audio (zero sized source also an option).
lavenderooze
THANK YOU SO MUCH!
