Ricks Tunes
Hello,
Using a 2018 Intel Mac Mini with Catalina Mac OS. Mem is 64 GB.
I am trying to setup to do an online stream to a casting website.
I have been able to configure MIxxx to send it's output to VB Audio cable, where the audio shows incoming on the control panel.
I do not see any output audio in the VB Audio Cable control panel. (VB Audio Cable 1.0.8)
OBS does not stream any audio, but does show "audio input capture" in the Audio Mixer column, but does not indicate any audio in the "VU Meter".
In settings under the Audio menu, VB-Cable is set as the Monitoring Device.
In advanced audio properties, the Audio Input Capture shows Active.
Audio Monitoring is set to "Monitor and Output".
Seems to me this should work, but no audio passes to OBS. (OBS Studio 26.1.2)
VB Audio Cable's settings only adjust latency.
Log File: https://obsproject.com/logs/1Z6Cdgad-nmYeNzb
