Matt Tolman
Logfile for current problem: https://obsproject.com/logs/J_voreZQRiKE__ym
Example of the audio: https://www.twitch.tv/videos/724396164
Audio chain/hardware/software (see attached)
Problem statement: Intermittently and without warning, my stream/recordings will get incredibly choppy and the log files will produce the Max Audio Buffering critical issue.
What I've tried doing to fix:
I'm at my wit's end I have no idea what to do to fix this and it's been causing me trouble and making me scrap footage for months.
Please help.
- Adjusted sync offset (current test, unconfirmed: needed to sync audio and video anyway)
- Got a powered USB hub and reorganize USBs to put the hardware with the most load to be directly plugged into the motherboard
- Adjusted (almost) all of my audio chain to be on the same frequency 2 channel 24bit 48khz
- Removing voicemeeter from my audio chain (thought it was causing the problem)
- Reaching out in multiple tech support communities, subreddits, including OBS discord
Please help.
