Hi,
There are many plugins I have installed to /usr/lib/vst that work in Ardour, but won't work in obs-studio. They show up, but when I click them in filters to open them, I get no plugin window popping up. Here is what it says in the terminal.
warning: Couldn't get a pointer to plug-in's main()
warning: VST Plug-in: Can't load effect!
In this case, the plugin was loudmax https://www.kvraudio.com/product/loudmax-by-thomas-mundt I also get the same behavior for lsp-plugins https://sourceforge.net/projects/lsp-plugins/files/lsp-plugins/1.1.30/
Plugins that DO work include maximal https://venomode.com/maximal and the daw essentials collection https://www.tracktion.com/products/daw-essentials-collection These plugins load as filters in obs - and WORK! The problem is that they are horrible products. Their limiters are filled with ugly, audible distortion at even 1-2 dB of gain reduction.
I would like to open up the base of plugins that I can use, which requires figuring out what this error above means. Any hints?
Thank you!
Thank you!
