Question / Help low quality when recording on 1920x1200
I would check out your video, but it says it's a duplicate and it won't show.
Did you try other resolutions first? Does OBS show any dropped frames? Is your PC good enough to record at that resolution?
If you could post a log file, that would be great. click
i tried 1080p but it didnt
work so i google a bit and i higherd my base and output resolution its all fixed now
