Sorry i'm going to post it raw in the this section :
15:50:10.992: CPU Name: Intel(R) Core(TM) i5-4570 CPU @ 3.20GHz
15:50:10.992: CPU Speed: 3200MHz
15:50:10.992: Physical Cores: 4, Logical Cores: 4
15:50:10.992: Physical Memory: 8054MB Total, 5229MB Free
15:50:10.992: Windows Version: 10.0 Build 15063 (revision: 674; 64-bit)
15:50:10.992: Running as administrator: true
15:50:10.992: Aero is Enabled (Aero is always on for windows 8 and above)
15:50:10.992: Portable mode: false
15:50:11.005: OBS 20.1.0 (64bit, windows)
15:50:11.005: ---------------------------------
15:50:11.006: ---------------------------------
15:50:11.006: audio settings reset:
15:50:11.006: samples per sec: 48000
15:50:11.006: speakers: 2
15:50:11.007: ---------------------------------
15:50:11.007: Initializing D3D11...
15:50:11.007: Available Video Adapters:
15:50:11.008: Adapter 1: NVIDIA GeForce GTX 1050 Ti
15:50:11.008: Dedicated VRAM: 4224712704
15:50:11.008: Shared VRAM: 4222617600
15:50:11.008: output 1: pos={0, 0}, size={1920, 1080}, attached=true
15:50:11.008: Adapter 2: Intel(R) HD Graphics 4600
15:50:11.008: Dedicated VRAM: 117964800
15:50:11.008: Shared VRAM: 2147483648
15:50:11.008: output 1: pos={1920, 130}, size={1360, 768}, attached=true
15:50:11.010: Loading up D3D11 on adapter NVIDIA GeForce GTX 1050 Ti (0)
15:50:11.040: D3D11 loaded successfully, feature level used: 45056
15:50:11.689: ---------------------------------
15:50:11.689: video settings reset:
15:50:11.689: base resolution: 1920x1080
15:50:11.689: output resolution: 1280x720
15:50:11.689: downscale filter: Bilinear
15:50:11.689: fps: 30/1
15:50:11.689: format: NV12
15:50:11.691: Audio monitoring device:
15:50:11.691: name: Par défaut
15:50:11.691: id: default
15:50:11.691: ---------------------------------
15:50:11.692: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
15:50:11.697: [CoreAudio encoder]: Adding CoreAudio AAC encoder
15:50:11.698: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
15:50:11.698: Failed to initialize module 'enc-amf.dll'
15:50:11.708: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
15:50:11.708: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
15:50:11.722: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
15:50:11.723: Failed to load 'en-US' text for module: 'obs-browser.dll'
15:50:11.723: [browser_source: 'Version: 1.29.0']
15:50:11.725: NVENC supported
15:50:11.739: Couldn't find VLC installation, VLC video source disabled
15:50:11.743: No blackmagic support
15:50:11.923: ---------------------------------
15:50:11.923: Loaded Modules:
15:50:11.923: win-wasapi.dll
15:50:11.923: win-mf.dll
15:50:11.923: win-ivcam.dll
15:50:11.923: win-dshow.dll
15:50:11.923: win-decklink.dll
15:50:11.923: win-capture.dll
15:50:11.923: vlc-video.dll
15:50:11.923: text-freetype2.dll
15:50:11.923: rtmp-services.dll
15:50:11.923: obs-x264.dll
15:50:11.923: obs-vst.dll
15:50:11.923: obs-transitions.dll
15:50:11.923: obs-text.dll
15:50:11.923: obs-qsv11.dll
15:50:11.923: obs-outputs.dll
15:50:11.923: obs-filters.dll
15:50:11.923: obs-ffmpeg.dll
15:50:11.923: obs-browser.dll
15:50:11.923: image-source.dll
15:50:11.923: frontend-tools.dll
15:50:11.923: enc-amf.dll
15:50:11.923: coreaudio-encoder.dll
15:50:11.923: ==== Startup complete ===============================================
15:50:11.933: All scene data cleared
15:50:11.933: ------------------------------------------------
15:50:11.982: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
15:50:12.011: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
15:50:12.053: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds
15:50:12.159: Switched to scene 'Stream'
15:50:12.159: ------------------------------------------------
15:50:12.159: Loaded scenes:
15:50:12.159: - scene 'Début de stream':
15:50:12.159: - source: 'Image' (image_source)
15:50:12.159: - source: 'Fond' (image_source)
15:50:12.159: - source: 'Le stream arrive' (text_gdiplus)
15:50:12.159: - filter: 'Défilement' (scroll_filter)
15:50:12.159: - source: 'Musique' (text_ft2_source)
15:50:12.159: - scene 'Stream':
15:50:12.159: - source: 'DAyz' (game_capture)
15:50:12.159: - source: 'PUBG' (game_capture)
15:50:12.159: - source: 'Streamlabs alerts' (browser_source)
15:50:12.159: - source: 'Chat' (browser_source)
15:50:12.159: - source: 'Bits' (browser_source)
15:50:12.159: - source: 'Webcam1' (image_source)
15:50:12.159: - source: 'Webcam' (dshow_input)
15:50:12.160: - scene 'Webcam only':
15:50:12.160: - source: 'Webcam' (dshow_input)
15:50:12.160: - scene 'THE MIGHTY JAR OF JARS':
15:50:12.160: - source: 'BrowserSource 4' (browser_source)
15:50:12.160: ------------------------------------------------
15:50:12.192: ---------------------------------
15:50:12.192: [DShow Device: 'Webcam'] settings updated:
15:50:12.192: video device: Logitech HD Pro Webcam C920
15:50:12.192: video path: \\?\usb#vid_046d&pid_082d&mi_00#6&297d2173&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\{bbefb6c7-2fc4-4139-bb8b-a58bba724083}
15:50:12.192: resolution: 640x480
15:50:12.192: fps: 30.00 (interval: 333333)
15:50:12.192: format: I420
15:50:28.933: ---------------------------------
15:50:28.933: [NVENC encoder: 'streaming_h264'] settings:
15:50:28.933: rate_control: CBR
15:50:28.933: bitrate: 6000
15:50:28.933: cqp: 0
15:50:28.933: keyint: 60
15:50:28.933: preset: bd
15:50:28.933: profile: main
15:50:28.933: level: auto
15:50:28.933: width: 1280
15:50:28.933: height: 720
15:50:28.933: 2-pass: true
15:50:28.933: b-frames: 2
15:50:28.933: GPU: 0
15:50:28.933:
15:50:29.505: [CoreAudio AAC: 'Track1']: settings:
15:50:29.505: mode: AAC
15:50:29.505: bitrate: 160
15:50:29.505: sample rate: 48000
15:50:29.505: cbr: on
15:50:29.505: output buffer: 1536
15:50:29.505: [rtmp stream: 'adv_stream'] Connecting to RTMP URL rtmp://live-fra.twitch.tv/app...
15:50:29.512: ==== Recording Start ===============================================
15:50:29.512: [ffmpeg muxer: 'adv_file_output'] Writing file 'C:/Users/The Almighty/Videos/2017-10-21 15-50-29.flv'...
15:50:29.528: [rtmp stream: 'adv_stream'] Interface: Realtek PCIe GBE Family Controller #2 (ethernet, 1000 mbps)
15:50:30.886: [rtmp stream: 'adv_stream'] Connection to rtmp://live-fra.twitch.tv/app successful
15:50:30.887: ==== Streaming Start ===============================================
15:50:34.637: [ffmpeg muxer: 'adv_file_output'] Output of file 'C:/Users/The Almighty/Videos/2017-10-21 15-50-29.flv' stopped
15:50:34.637: Output 'adv_file_output': stopping
15:50:34.637: Output 'adv_file_output': Total frames output: 140
15:50:34.637: Output 'adv_file_output': Total drawn frames: 154
15:50:34.637: ==== Recording Stop ================================================
15:51:07.925: [game-capture: 'PUBG'] attempting to hook process: TslGame.exe
15:51:07.928: [game-capture: 'PUBG'] using helper (compatibility hook)
15:51:07.930: [game-capture: 'PUBG'] hook not loaded yet, retrying..
15:51:10.958: [game-capture: 'PUBG'] attempting to hook process: TslGame.exe
15:51:11.991: [game-capture: 'PUBG'] capture stopped
15:51:14.991: [game-capture: 'PUBG'] attempting to hook process: TslGame.exe
15:51:15.024: [game-capture: 'PUBG'] shared texture capture successful
16:02:31.284: [game-capture: 'PUBG'] capture window no longer exists, terminating capture
16:02:31.396: [game-capture: 'PUBG'] capture stopped
16:02:45.059: [rtmp stream: 'adv_stream'] User stopped the stream
16:02:45.077: Output 'adv_stream': stopping
16:02:45.077: Output 'adv_stream': Total frames output: 21973
16:02:45.077: Output 'adv_stream': Total drawn frames: 12941 (22067 attempted)
16:02:45.077: Output 'adv_stream': Number of lagged frames due to rendering lag/stalls: 9126 (41.4%)
16:02:45.091: [rtmp stream: 'adv_stream'] Freeing 5 remaining packets
16:02:45.626: ==== Streaming Stop ================================================
I've put the fps at 30 as you reccomended but stil same drop on stream no impact on my gameplay.
