Lossless Audio Encoder when output mode is Simple
search
The output mode is simple, and when you select high quality or ultra high quality for the recording quality, you can choose the audio encoder from AAC or Opus, but both are lossy compression encoders and the audio bitrate is fixed at 192kbps. I would like it to be possible to select lossless audio encoders such as FLAC encoder or PCM encoder.
search
While I agree that this would be a nice feature to have, why not just use the advanced mode?
It's true that using Advanced mode could solve the problem, but Simple mode is good enough for me. Using Advanced mode takes a lot of time to adjust. When recording in Simple mode, it would be much easier to use if the audio encoder was in FLAC or PCM format. Since audio takes up less space than video, I would like to use a lossless format.
