Question / Help Logitech C920 1080p problems AND Green Screen problems
MrLucyTheBoxer
Hi,
I'm new to OBS but am pretty tech savvy and am pretty comfortable with how it all works. However, I'm having two problems:
The details:
  • 2017 MacBook Pro 13-inch non-touchpad
  • macOS Mojave
  • OBS (most recent version, fully updated)
  • Logitech C920 1080p WebCam
  1. My Logitech C920 won't do a resolution higher than 720p in OBS. Any tips to make this work?
    • I have tried starting Quicktime and setting it to 'maximum' but that doesn't make a difference in OBS
    • Have downloaded latest version of Logi Capture, which has made no difference
  2. I have a green screen and lights, and have been using the setup with Zoom.us perfectly for virtual background. However...
    • When attempting to use in OBS, OBS doesn't seem to recognise my green screen
    • I can't manually select the colour from my screen as the tool doesn't work
    • When I enter a colour code manually, OBS still won't pick it up
    • The best I can get is a kind of fuzzy half and half that isn't going to work
Any help will be greatly appreciated.
Thanks,
Ben
