XaviC
Hi,
I’ve noticed that my Linux recordings sound worse than my macOS ones—even though I haven’t modified any default settings in OBS.
I installed OBS on both my Linux Mint ThinkPad and my MacBook Pro, and I’m using the same microphone and camera for both.
Even though the OBS settings are identical (I don’t recall changing any defaults), the audio quality on Linux is noticeably worse than on macOS. The video/camera quality, however, is very similar—if not identical.
On Linux, the only setting I’ve adjusted is the audio input volume, to prevent the recording from being too loud. Everything else remains at default.
What could be causing this difference? Is it related to my OBS configuration, or is it something deeper in the OS audio stack?
I’ve attached two sample videos—one recorded on macOS and one on Linux—so you can hear and see the difference for yourself.
Thanks in advance!
drive.google.com
Thanks in advance!
forum videos – Google Drive
drive.google.com
