Question / Help LGP Stream Engine not showing on Game Capture // Audio glitching
Catarina Sousa
Hey everyone.
I'm streaming from Xbox One with my game capture from Avermedia, the LGP.
So I used a video capture device for the Game Capture and the only thing that shows is Avermedia C875 Capture, and it works! BUT, the audio is glitching, I can't change to WaveOut in the Audio exit or it stops the image from the Xbox (That was what it worked for my boyfriend with the PS4).
So I really need your help on this.
I have the LGP Stream Engine updated and it's enabled
Make sure you're running the 32-bit version of OBS. Stream Engine doesn't have 64-bit DirectShow drivers and won't be listed in 64-bit OBS.
