Bug Report LGP Sound Problems
JohnPlays
When using my Avermedia Live Gamer Portable I get very choppy/laggy audio but the video is completely fine.
Gol D. Ace
Use the stream engine and redownload OBS Studio 0.13.2 (if you had 0.13.2 installed before).
The internal decoding will most likely never work correctly because AVerMedia isn't providing correct timestamps for the audio.
JohnPlays
I won't be able to send a log because I tried a few options last night to see if I could fix it myself, but I could link you some footage?
