Question / Help (LAG And Horrible quality) Please help!
Zytin
When i record desktop/games it comes out with horrible quality. Ive been tweaking with it and when I get good frames in game and i see that obs is recording fine. But when i go to open the file of recording it has the worst lag ive ever seen. These are my specs. (Im not streaming) I want to make note that ive been using dxtory and it has ok quality with decent frames. However i want to use obs because of the optimizations and filter you can use.
Windows 10 pro
Processor Intel(R) Pentium(R) CPU G2020 @ 2.90GHz 2.90 Ghz
Ram: 8.00GB
System type 64 bit
Zytin
Post your obs log.
16:40:13.937: CPU Name: Intel(R) Pentium(R) CPU G2020 @ 2.90GHz
16:40:13.937: CPU Speed: 2893MHz
16:40:13.937: Physical Cores: 2, Logical Cores: 2
16:40:13.937: Physical Memory: 8143MB Total, 5230MB Free
16:40:13.937: Windows Version: 10.0 Build 14393 (revision: 1198; 64-bit)
16:40:13.937: Running as administrator: false
16:40:13.937: Aero is Enabled (Aero is always on for windows 8 and above)
16:40:13.938: Portable mode: false
16:40:14.000: OBS 19.0.2 (64bit, windows)
16:40:14.000: ---------------------------------
16:40:14.001: audio settings reset:
16:40:14.001: samples per sec: 44100
16:40:14.001: speakers: 2
16:40:14.094: ---------------------------------
16:40:14.094: Initializing D3D11...
16:40:14.094: Available Video Adapters:
16:40:14.095: Adapter 1: NVIDIA GeForce GTX 560 Ti
16:40:14.095: Dedicated VRAM: 1027014656
16:40:14.095: Shared VRAM: 4269340672
16:40:14.095: output 1: pos={0, 0}, size={1600, 900}, attached=true
16:40:14.095: output 2: pos={1600, 91}, size={1920, 1080}, attached=true
16:40:14.098: Loading up D3D11 on adapter NVIDIA GeForce GTX 560 Ti (0)
16:40:14.301: D3D11 loaded successfully, feature level used: 45056
16:40:15.405: ---------------------------------
16:40:15.405: video settings reset:
16:40:15.405: base resolution: 1280x720
16:40:15.405: output resolution: 640x360
16:40:15.405: downscale filter: Bilinear
16:40:15.405: fps: 30/1
16:40:15.405: format: NV12
16:40:15.406: Audio monitoring device:
16:40:15.406: name: Default
16:40:15.406: id: default
16:40:15.406: ---------------------------------
16:40:15.504: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/chrome_elf.dll' not found, loading of module failed
16:40:15.551: [CoreAudio encoder]: Adding CoreAudio AAC encoder
16:40:15.573: [AMF] Encountered Exception during AMF initialization: Unable to load 'amfrt64.dll', error code 126.
16:40:15.573: Failed to initialize module 'enc-amf.dll'
16:40:15.717: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libcef.dll' not found, loading of module failed
16:40:15.861: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libEGL.dll' not found, loading of module failed
16:40:15.874: Required module function 'obs_module_load' in module '../../obs-plugins/64bit/libGLESv2.dll' not found, loading of module failed
16:40:15.893: Failed to load 'en-US' text for module: 'obs-browser.dll'
16:40:15.893: [browser_source: 'Version: 1.29.0']
16:40:16.020: LoadLibrary failed for 'nvEncodeAPI64.dll': The specified module could not be found.
16:40:16.020: (126)
16:40:16.347: Couldn't find VLC installation, VLC video source disabled
16:40:16.450: No blackmagic support
16:40:16.550: ---------------------------------
16:40:16.550: Loaded Modules:
16:40:16.550: win-wasapi.dll
16:40:16.550: win-mf.dll
16:40:16.550: win-dshow.dll
16:40:16.550: win-decklink.dll
16:40:16.550: win-capture.dll
16:40:16.550: vlc-video.dll
16:40:16.550: text-freetype2.dll
16:40:16.550: rtmp-services.dll
16:40:16.550: obs-x264.dll
16:40:16.550: obs-vst.dll
16:40:16.550: obs-transitions.dll
16:40:16.550: obs-text.dll
16:40:16.550: obs-qsv11.dll
16:40:16.550: obs-outputs.dll
16:40:16.550: obs-filters.dll
16:40:16.550: obs-ffmpeg.dll
16:40:16.550: obs-browser.dll
16:40:16.550: image-source.dll
16:40:16.550: frontend-tools.dll
16:40:16.550: enc-amf.dll
16:40:16.550: coreaudio-encoder.dll
16:40:16.550: ==== Startup complete ===============================================
16:40:16.561: Service '' not found
16:40:16.575: All scene data cleared
16:40:16.575: ------------------------------------------------
16:40:16.784: WASAPI: Device 'Speakers (Realtek High Definition Audio)' initialized
16:40:16.836: adding 46 milliseconds of audio buffering, total audio buffering is now 46 milliseconds
16:40:16.989: WASAPI: Device 'Microphone (Realtek High Definition Audio)' initialized
16:40:17.526: Switched to scene 'Desktop/Browser Recorder'
16:40:17.528: ------------------------------------------------
16:40:17.528: Loaded scenes:
16:40:17.528: - scene 'Scene':
16:40:17.528: - scene 'Desktop/Browser Recorder':
16:40:17.528: - source: 'Display Capture' (monitor_capture)
16:40:17.528: - scene 'Game Capture':
16:40:17.528: - source: 'Game Capture ' (game_capture)
16:40:17.528: - scene 'Stream':
16:40:17.528: - source: 'Display' (monitor_capture)
16:40:18.231: adding 23 milliseconds of audio buffering, total audio buffering is now 69 milliseconds
Harold
Change the recording format back to flv and change the encoder to software low cpu use.
