Issues with ISHOWU and OBS whilst using Traktor Kontrol S4 MK3
jc1620
Whilst using OBS with ISHOWU driver I am experiencing issues with output whilst using the settings shown in several videos on youtube when the Traktor software is set up for output on the multi-output device I get no signal through OBS on AUX2 however when I go into Traktor settings and set output from Traktor to the controller instead of the multi-output channel I set up I get output on AUX2 however I lose the ability to monitor pre-mix through Kontrol S4 even when switched to full unless I slide the vertical fader up on that channel then I can start to hear the incoming channel.
Any Ideas Guys?
