Bug Report Issues using Logitech C922 Pro webcam - vid configure/obs options
lordasp
Ok, I recently bought a Logitech C922 Pro webcam to upgrade my C920 so I can use 60fps instead of 30fps. Camera shows up in my options. The problems are the following:
1. In OBS when you click the Configure Video to access the camera's software, it brings up some generic options screen that doesn't update in real time.
2. on the C920 you had a couple of choices in OBS once you changed resolution/fps type to custom to be able to change the video format type. I used this to get a better looking webcam image via obs. With the C922 Pro, the Video Format drop down only shows Any and no MJpg or the other options that were available for the 920.
Anyway to get it to point to the actual Logitech camera software like it did for the 920?
3.I hadn't done any cropping of the camera inside OBS with the filters yet I noticed if I even minutely zoomed the camera in once, OBS immediately cropped the image on the sides but left a biiiig black gap kind of like opposite black bars you'd see on top and bottom of widescreen movies.
