I just started using the wonderful OBS software on my Macbook.
I found it complicated to record the computer audio (on a Mac) - as far as i understand, the only way to do that, is to use a third-party application - iShowU Audio Capture to record the computer audio.
* i tested it on a regular PC and it's was simple!
Just need change the Desktop Audio (settings) as you wish.
Is there a simpler way to do this?
