iPad/iPhone audio in OBS Studio solution using Zoom
TripleN
Don't know if it's already been posted but i found a workaround for the problem that the iPad audio is not passed to OBS.
I connect my iPad with the lightning usb cable and add the iPad to OBS to share the screen.
Most of you know that there is no audio from the iPad.
Then i start a meeting in Zoom (no participants) and use the Share screen option to share the screen of the iPad with 'iPhone/iPad via Cable' option.
I also check the option to 'Share sound'.
Zoom is now creating a meeting and will share the screen and also the audio of my iPad.
I can obviously share this window with OBS using Window capture but use Zoom only for the audio part.
In the MIDI app of OSX there is a ZoomAudioDevice channel. I don't know exactly if this came with the Zoom installation.
But in OBS i can use this channel as Audio input.
And now i have the audio of my iPad in OBS using the audio from my Zoom meeting and the screen part directly from the iPad.
Hope this wil help others as well.
