Spookopheles
This is only a mockup and value numbers are inaccurate. I'm mostly curious of what others think of the idea.
Tracks and Mono button are togglable, theyd light up for on or be dark for off. "Active" statuses are the red dot to the left of each channel's name, which is fine if my assumption that active and inactive are the only states for that. The thickness of each channel slot is about equal to the current one, because the volume slider is reduced in size, so there is no increase in vertical space. Sync Offset isn't something i really use, so i didn't think it appropriate to determine its new location myself. To reduce visual confusion from the clutter, ive given each channel a kind of background color, where the advanced audio options act a bit like separators visually.
Now, im sure this wouldnt really work for the mixer if it was set in the vertical layout. I forgot you can do that when i made this. A different design would be needed for that, like for example, buttons with icons instead of text.
In regards to hidden items, the current Advanced Audio Properties menu could be retrofitted to be a Hidden Audio menu instead, which would also remove the need to search for hidden audio channels among non-hidden ones on the list.
