Question / Help Imediately help needed!Encoder problem!Tried everything
Harry 0fficial
Gretings!I would really apreciate any help given as i searched everything for the Encoder overload problem i have,i tried everything,(as i had a GTX 750 2gb and a I5-4400 i was able to record in full hd 60fps all games normally,this week i got a new MSI gtx 1060 6gb,whenever i try to record,i have the encoder problem,i am begging for help as i have a scheduled livestream this friday!Thanks a lot your reply is higly apreciated!if there is anything you want to ask me for you can in this thread(16gb memory btw)
Fenrir
Forum Admin
Please post a link to a clean log file. To make a clean log file, first restart OBS, then start your stream/recording for ~30 seconds and stop it again. Make sure you replicate any issues as best you can, which means having any games/apps open and captured, etc. When you're done select Help > Log Files > Upload Current Log File. Copy the URL and paste it here.
Harry 0fficial
Of course i will after school,but i have a question,you want me to record trying to lower the setting as much as possible or just record with the encoder provblem?
Fenrir
Forum Admin
07:09:16.734: Output 'adv_file_output': Number of skipped frames due to encoding lag: 177 (5.1%)
07:09:16.734: Output 'adv_file_output': Number of lagged frames due to rendering lag/stalls: 92 (2.6%)
Your PC cannot handle 1080p 60fps encoding. Try lowering resolution to 720p or FPS to 30.
Fenrir
Forum Admin
Make sure you're capping FPS in overwatch, it will quickly max out your GPU if you are not.
Harry 0fficial
you mean adding a limit?just before a friend of mine turned on VSYNC for stabilised fps,i now have aplwaya 60,should i try adding a limit?at 60 which doesnt drop more than that?is that what you are saying?
Harry 0fficial
i got these links:http://gpuz.techpowerup.com/17/04/25/s7y.png
Harry 0fficial
OMG!!i tried and i can see a awesome framerate!i would like to test with max quality so in the outpout tab recording>should i use NVEC or x264? bigger bitrate more quality? and whitch preset?I would like to thank you you are a lifesaver,i really wish i could thank you with something more than just thanks!
Harry 0fficial
i think the advanced works fine 60 fps no drops and warnings,but while recording in the preview there are like 3 fps but the video is fine with 70% quality
Boildown
After your latest changes, do a 5 minute encode of high action content and then upload that log file so we can see it.
