FlashBowski
Hey all.
I've been through the mill with this one and looked at every video, every forum, done multiple google searches but am stumped as to how to work around this problem.
My stream setup is VERY complex and involves multiple sources, green screens, etc.
I had normally ran a 2 pc setup with one pc for gaming into a second pc for streaming. Over time will all the issues I was having and also because I wanted to upgrade anyway, I purtrchased a 3rd PC.
The thried PC would now deal with the gaming, the second PC would deal with the multiple scenes etc for the stream and the third would be for encoding and sending out the stream itself.
So, to simplify; Gaming PC capture card to "production PC" (which would deal with sources etc and record the stream for further use" and this would then send the signal via NDI to the production PC that would simply encode the stream and push it out.
The issue I'm having is the audio lag. The recording is perfectly in sink but the stream, is laggy. I can see m,yself talk a good second before the audio comes through and it's basically turning into a bit of a nightmare. I'm tweaking stuff on the production PC but I'm cnscious that I might be putting the cart before the horse and need to change stuff on the streaming pc.
Any help would be appreciated.
