Ubuntu 15.04.
First, I'm unable to get OBS capturing sound from the computer. The microphone sound works perfectly, but I can't get any response from the computer sound.
Also I have a small question. How does the Encoder Preset affects the recording/streaming?
Second, the quality is really bad. I tried tweaking the settings, but I'm unable to get it better than this video.
https://www.youtube.com/watch?v=bAxWBsGA0Ts
01:35:36.804: OBS 0.11.2 (linux)
01:35:36.804: ---------------------------------
01:35:36.866: Processor: 8 logical cores
01:35:36.866: Processor: Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
01:35:36.867: Physical Memory: 16008MB Total
01:35:36.867: Kernel Version: Linux 3.19.0-26-generic
01:35:36.867: Distribution: "Ubuntu" "15.04"
01:35:36.867: ---------------------------------
01:35:36.867: audio settings reset:
01:35:36.867: samples per sec: 44100
01:35:36.867: speakers: 2
01:35:36.867: buffering (ms): 1000
01:35:36.877: X and Y: 1262 459
01:35:36.877: Backbuffers: 2
01:35:36.877: Color Format: 3
01:35:36.877: ZStencil Format: 0
01:35:36.877: Adapter: 0
01:35:36.877:
01:35:37.038: OpenGL version: 3.2.0 NVIDIA 346.59
01:35:37.038:
01:35:37.044: ---------------------------------
01:35:37.044: video settings reset:
01:35:37.044: base resolution: 1920x1080
01:35:37.044: output resolution: 1280x720
01:35:37.044: fps: 30/1
01:35:37.044: format: NV12
01:35:37.045: ---------------------------------
01:35:37.045: Loading module: image-source.so
01:35:37.045: Loading module: linux-capture.so
01:35:37.047: ---------------------------------
01:35:37.047: Loading module: linux-decklink.so
01:35:37.047: No blackmagic support
01:35:37.047: Failed to start search for DeckLink devices
01:35:37.048: ---------------------------------
01:35:37.048: Loading module: linux-jack.so
01:35:37.049: ---------------------------------
01:35:37.049: Loading module: linux-pulseaudio.so
01:35:37.050: ---------------------------------
01:35:37.050: Loading module: linux-v4l2.so
01:35:37.053: ---------------------------------
01:35:37.053: Loading module: obs-ffmpeg.so
01:35:37.054: ---------------------------------
01:35:37.054: Loading module: obs-filters.so
01:35:37.054: Loading module: obs-libfdk.so
01:35:37.055: ---------------------------------
01:35:37.055: Loading module: obs-outputs.so
01:35:37.055: Loading module: obs-x264.so
01:35:37.056: ---------------------------------
01:35:37.056: Loading module: rtmp-services.so
01:35:37.057: ---------------------------------
01:35:37.057: Loading module: text-freetype2.so
01:35:37.057: =====================================================================
01:35:37.057: output 'adv_stream' (rtmp_output) created
01:35:37.057: output 'adv_file_output' (ffmpeg_muxer) created
01:35:37.057: encoder 'recording_h264' (obs_x264) created
01:35:37.057: encoder 'streaming_h264' (obs_x264) created
01:35:37.058: AAC encoder bitrate mapping:
01:35:37.058: 32 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 64 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 96 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 128 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 160 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 192 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 224 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 256 kbit/s: 'libfdk AAC Encoder' (libfdk_aac)
01:35:37.058: 288 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
01:35:37.058: 320 kbit/s: 'FFmpeg Default AAC Encoder' (ffmpeg_aac)
01:35:37.058: encoder 'adv_aac0' (libfdk_aac) created
01:35:37.058: encoder 'adv_aac1' (libfdk_aac) created
01:35:37.058: encoder 'adv_aac2' (libfdk_aac) created
01:35:37.058: encoder 'adv_aac3' (libfdk_aac) created
01:35:37.060: service 'default_service' (rtmp_common) created
01:35:37.069: All scene data cleared
01:35:37.069: ------------------------------------------------
01:35:37.073: pulse-input: Server name: 'pulseaudio 6.0'
01:35:37.073: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
01:35:37.073: pulse-input: Started recording from 'alsa_output.usb-Logitech_Logitech_G930_Headset-00-Headset.analog-stereo.monitor'
01:35:37.073: source 'Desktop Audio' (pulse_output_capture) created
01:35:37.073: pulse-input: Started recording from 'alsa_input.usb-Samson_Technologies_Samson_Meteor_Mic-00-Mic.analog-stereo'
01:35:37.074: source 'Mic/Aux' (pulse_input_capture) created
01:35:37.074: source 'Scene' (scene) created
01:35:37.090: xcompcap: XCompositeNameWindowPixmap failed: BadMatch (invalid parameter attributes)
01:35:37.090: source 'Window Capture (Xcomposite)' (xcomposite_input) created
01:35:37.935: Update check: last known remote version is 0.4.0
01:37:45.588: encoder 'recording_h264' destroyed
01:37:45.588: encoder 'streaming_h264' destroyed
01:37:45.588: encoder 'adv_aac3' destroyed
01:37:45.588: encoder 'adv_aac2' destroyed
01:37:45.588: encoder 'adv_aac1' destroyed
01:37:45.588: encoder 'adv_aac0' destroyed
01:37:45.588: output 'adv_stream' destroyed
01:37:45.588: output 'adv_file_output' destroyed
01:37:45.588: output 'simple_stream' (rtmp_output) created
01:37:45.588: output 'simple_file_output' (ffmpeg_muxer) created
01:37:45.588: encoder 'simple_h264' (obs_x264) created
01:37:45.588: encoder 'simple_aac' (libfdk_aac) created
01:37:45.588: Settings changed (outputs)
01:37:45.588: ------------------------------------------------
01:37:57.693: ---------------------------------
01:37:57.693: video settings reset:
01:37:57.693: base resolution: 1920x1080
01:37:57.693: output resolution: 1920x1080
01:37:57.693: fps: 30/1
01:37:57.693: format: NV12
01:37:57.694: Settings changed (video)
01:37:57.694: ------------------------------------------------
01:38:48.381: encoder 'simple_h264' destroyed
01:38:48.381: encoder 'simple_aac' destroyed
01:38:48.381: output 'simple_stream' destroyed
01:38:48.381: output 'simple_file_output' destroyed
01:38:48.381: output 'simple_stream' (rtmp_output) created
01:38:48.381: output 'simple_file_output' (ffmpeg_muxer) created
01:38:48.381: encoder 'simple_h264' (obs_x264) created
01:38:48.381: encoder 'simple_aac' (libfdk_aac) created
01:38:48.381: Settings changed (outputs)
01:38:48.381: ------------------------------------------------
01:39:08.168: encoder 'simple_h264' destroyed
01:39:08.185: encoder 'simple_aac' destroyed
01:39:08.185: output 'simple_stream' destroyed
01:39:08.185: output 'simple_file_output' destroyed
01:39:08.185: output 'simple_stream' (rtmp_output) created
01:39:08.185: output 'simple_file_output' (ffmpeg_muxer) created
01:39:08.185: encoder 'simple_h264' (obs_x264) created
01:39:08.185: encoder 'simple_aac' (libfdk_aac) created
01:39:08.185: Settings changed (outputs)
01:39:08.185: ------------------------------------------------
01:39:27.796: xcompcap: XCompositeNameWindowPixmap failed: BadMatch (invalid parameter attributes)
01:39:55.683: Settings changed (audio)
01:39:55.683: ------------------------------------------------
01:40:20.026: xcompcap: XCompositeRedirectWindow failed: BadWindow (invalid Window parameter)
01:40:22.409: source 'Desktop Audio' destroyed
01:40:22.409: pulse-input: Stopped recording from 'alsa_output.usb-Logitech_Logitech_G930_Headset-00-Headset.analog-stereo.monitor'
01:40:22.409: pulse-input: Got 341997 packets with 12589736 frames
01:40:22.434: source 'Mic/Aux' destroyed
01:40:22.434: pulse-input: Stopped recording from 'alsa_input.usb-Samson_Technologies_Samson_Meteor_Mic-00-Mic.analog-stereo'
01:40:22.435: pulse-input: Got 170523 packets with 12584827 frames
01:40:22.452: source 'Scene' destroyed
01:40:22.453: source 'Window Capture (Xcomposite)' destroyed
01:40:22.454: All scene data cleared
01:40:22.454: ------------------------------------------------
01:40:22.454: service 'default_service' destroyed
01:40:22.454: encoder 'simple_h264' destroyed
01:40:22.454: encoder 'simple_aac' destroyed
01:40:22.454: output 'simple_stream' destroyed
01:40:22.454: output 'simple_file_output' destroyed
01:40:22.526: Freeing OBS context data
01:40:22.618: Number of memory leaks: 0
