I need your help... Asio Input capture disconnecting problem.
sunggun2001
I'm using UAD apollo twin x duo(thundervolt) in Windows.
So i have to use Asio input captrue.
but there's some problems.
When i'm streaming, it keeps disconnecting in OBS.
I think its for computer resources problem because when i play WOW, the disconnecting problem happened little bit.
However, playing Diablo 4, when i move maps and loading, sound signals kept disconnected.
whats the strange things that, if i changed the asio input capture channel in OBS
(ex : Mic1 -> Aux1 -> again Mic 1)
it works again(signals on) but 2~3 mins later again work out(signals disconnecting).
Only it happened using Asio input capture.
Please... somebody help me.
it makes me crazy.
My computer has thundervolt port
3080ti graphic and 12900k i9 intel cpu
32gb ddr5 ram.
