Question / Help I need to know settings for 240p quality with low upload speed
POJO71
My upload is .7 (which is the best I can get with my DSL internet) and I know I will need some for my internet so, I would like to know some settings that would work. Also, if it helps any I have an i3-4150 (I am gonna get an i5-6600k in a month or two) processor The only game I will be streaming is minecraft
Also does it matter if I have OBS classic or studio, what is the difference.
retroday
When you get i5-6600k, overclock it, set CPU Encoding Preset to Very Slow, downscale to 360p, give 500 bitrate, audio mono, audio bitrate 64.
Don't listen to anyone who says you cannot stream. There are partnered streamers who have your upload speed. Good luck!
TryHD
An i5 can't do veryslow, so your suggestion is quite bad.
I tryed 360p at 24 fps encoded at veryslow and it works but still looks awfull.
For a good looking stream i would recommend atleast 5 MBit/s upload, preferable more
retroday
You are telling me I've been doing something impossible for the past 3 months with my i5 4690? You obviously cannot do it on 720p, this advice is for downscaled resolutions.
D
Deleted member 70571
Use 500 bitrate. Slower CPU presets can improve quality, albeit not a lot.
