20:46:49.376: Command Line Arguments: --safe-mode
20:46:49.376: CPU Name: 12th Gen Intel(R) Core(TM) i7-12700KF
20:46:49.377: CPU Speed: 3610MHz
20:46:49.377: Physical Cores: 12, Logical Cores: 20
20:46:49.377: Physical Memory: 32607MB Total, 22667MB Free
20:46:49.377: Windows Version: 10.0 Build 22631 (release: 23H2; revision: 3447; 64-bit)
20:46:49.377: Running as administrator: true
20:46:49.377: Windows 10/11 Gaming Features:
20:46:49.377: Game DVR: On
20:46:49.377: Game Mode: Off
20:46:49.377: Sec. Software Status:
20:46:49.378: Kaspersky: enabled (AV)
20:46:49.378: Microsoft Defender Antivírus: disabled (AV)
20:46:49.378: Kaspersky: enabled (FW)
20:46:49.378: Firewall do Windows: disabled (FW)
20:46:49.378: Current Date/Time: 2024-04-10, 20:46:49
20:46:49.378: Browser Hardware Acceleration: true
20:46:49.378: Hide OBS windows from screen capture: false
20:46:49.378: Qt Version: 6.6.2 (runtime), 6.6.2 (compiled)
20:46:49.378: Portable mode: false
20:46:49.378: Safe Mode enabled.
20:46:49.484: OBS 30.1.2 (64-bit, windows)
20:46:49.484: ---------------------------------
20:46:49.519: ---------------------------------
20:46:49.519: audio settings reset:
20:46:49.519: samples per sec: 48000
20:46:49.519: speakers: 2
20:46:49.519: max buffering: 960 milliseconds
20:46:49.519: buffering type: dynamically increasing
20:46:49.521: ---------------------------------
20:46:49.521: Initializing D3D11...
20:46:49.521: Available Video Adapters:
20:46:49.524: Adapter 0: NVIDIA GeForce RTX 3070
20:46:49.524: Dedicated VRAM: 8407482368 (7.8 GiB)
20:46:49.524: Shared VRAM: 17095530496 (15.9 GiB)
20:46:49.524: PCI ID: 10de:2488
20:46:49.524: HAGS Status: Enabled (Default: No, Driver status: Supported)
20:46:49.524: Driver Version: 31.0.15.5212
20:46:49.524: output 0:
20:46:49.524: name=LG HDR 4K
20:46:49.524: pos={0, 0}
20:46:49.524: size={3840, 2160}
20:46:49.524: attached=true
20:46:49.524: refresh=60
20:46:49.524: bits_per_color=8
20:46:49.524: space=RGB_FULL_G22_NONE_P709
20:46:49.524: primaries=[r=(0.680664, 0.311523), g=(0.267578, 0.663086), b=(0.150391, 0.048828), wp=(0.312500, 0.329102)]
20:46:49.524: relative_gamut_area=[709=1.316109, P3=0.970197, 2020=0.696052]
20:46:49.524: sdr_white_nits=80
20:46:49.524: nit_range=[min=0.354600, max=343.748291, max_full_frame=343.748291]
20:46:49.524: dpi=144 (150%)
20:46:49.524: id=\\?\DISPLAY#GSM7750#5&3514c544&0&UID4355#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
20:46:49.524: alt_id=\\.\DISPLAY2
20:46:49.525: output 1:
20:46:49.525: name=LF24T35
20:46:49.525: pos={-1920, 0}
20:46:49.525: size={1920, 1080}
20:46:49.525: attached=true
20:46:49.525: refresh=75
20:46:49.525: bits_per_color=8
20:46:49.525: space=RGB_FULL_G22_NONE_P709
20:46:49.525: primaries=[r=(0.639648, 0.356445), g=(0.303711, 0.631836), b=(0.147461, 0.051758), wp=(0.313477, 0.329102)]
20:46:49.525: relative_gamut_area=[709=1.061579, P3=0.782565, 2020=0.561438]
20:46:49.525: sdr_white_nits=80
20:46:49.525: nit_range=[min=0.500000, max=270.000000, max_full_frame=270.000000]
20:46:49.525: dpi=96 (100%)
20:46:49.525: id=\\?\DISPLAY#SAM707D#5&3514c544&0&UID4354#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}
20:46:49.525: alt_id=\\.\DISPLAY1
20:46:49.525: Loading up D3D11 on adapter NVIDIA GeForce RTX 3070 (0)
20:46:49.578: D3D11 loaded successfully, feature level used: b000
20:46:49.579: DXGI increase maximum frame latency success
20:46:49.579: Hardware-Accelerated GPU Scheduling enabled on adapter!
20:46:49.579: D3D11 GPU priority setup success
20:46:49.621: ---------------------------------
20:46:49.621: video settings reset:
20:46:49.621: base resolution: 3840x2160
20:46:49.621: output resolution: 3840x2160
20:46:49.621: downscale filter: Lanczos
20:46:49.621: fps: 60/1
20:46:49.621: format: NV12
20:46:49.621: YUV mode: Rec. 709/Full
20:46:49.621: NV12 texture support enabled
20:46:49.621: P010 texture support not available
20:46:49.622: Audio monitoring device:
20:46:49.622: name: Padrão
20:46:49.622: id: default
20:46:49.622: ---------------------------------
20:46:49.623: No AJA devices found, skipping loading AJA UI plugin
20:46:49.623: Failed to initialize module 'aja-output-ui.dll'
20:46:49.624: No AJA devices found, skipping loading AJA plugin
20:46:49.624: Failed to initialize module 'aja.dll'
20:46:49.624: Skipping module '../../obs-plugins/64bit/chrome_elf.dll', not an OBS plugin
20:46:49.625: [CoreAudio encoder]: CoreAudio AAC encoder not installed on the system or couldn't be loaded
20:46:49.625: Failed to load 'en-US' text for module: 'decklink-captions.dll'
20:46:49.625: Failed to load 'en-US' text for module: 'decklink-output-ui.dll'
20:46:49.626: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
20:46:49.626: Failed to initialize module 'decklink.dll'
20:46:49.627: Skipping module '../../obs-plugins/64bit/DirectML.dll', not an OBS plugin
20:46:49.627: Skipping module 'enc-amf', not on safe list
20:46:49.627: Skipping module 'frontend-tools', not on safe list
20:46:49.627: Skipping module '../../obs-plugins/64bit/libcef.dll', not an OBS plugin
20:46:49.627: Skipping module '../../obs-plugins/64bit/libEGL.dll', not an OBS plugin
20:46:49.627: Skipping module '../../obs-plugins/64bit/libGLESv2.dll', not an OBS plugin
20:46:49.627: Skipping module 'obs-backgroundremoval', not on safe list
20:46:49.635: [obs-browser]: Version 2.23.4
20:46:49.635: [obs-browser]: CEF Version 103.0.5060.134 (runtime), 103.0.0-5060-shared-textures.2594+gc69ad37+chromium-103.0.5060.134 (compiled)
20:46:49.637: NVENC supported
20:46:49.733: [NVENC] AV1 is not supported
20:46:49.734: [noise suppress]: NVIDIA denoiser disabled, redistributable not found or could not be loaded.
20:46:49.734: Failed to get NVVideoEffects.dll version info size
20:46:49.734: [NVIDIA VIDEO FX]: FX disabled, redistributable not found or could not be loaded.
20:46:49.762: Skipping module 'obs-websocket', not on safe list
20:46:49.765: [vlc-video]: VLC 3.0.20 Vetinari found, VLC video source enabled
20:46:49.770: ---------------------------------
20:46:49.770: Loaded Modules:
20:46:49.770: win-wasapi.dll
20:46:49.770: win-dshow.dll
20:46:49.770: win-capture.dll
20:46:49.770: vlc-video.dll
20:46:49.770: text-freetype2.dll
20:46:49.770: rtmp-services.dll
20:46:49.770: obs-x264.dll
20:46:49.770: obs-webrtc.dll
20:46:49.770: obs-vst.dll
20:46:49.770: obs-transitions.dll
20:46:49.770: obs-text.dll
20:46:49.770: obs-qsv11.dll
20:46:49.770: obs-outputs.dll
20:46:49.770: obs-filters.dll
20:46:49.770: obs-ffmpeg.dll
20:46:49.770: obs-browser.dll
20:46:49.770: image-source.dll
20:46:49.770: decklink-output-ui.dll
20:46:49.770: decklink-captions.dll
20:46:49.770: coreaudio-encoder.dll
20:46:49.770: QWidget::setTabOrder: 'first' and 'second' must be in the same window
20:46:49.770: ==== Startup complete ===============================================
20:46:49.798: All scene data cleared
20:46:49.798: ------------------------------------------------
20:46:49.799: [win-wasapi: 'Mic/Aux'] update settings:
20:46:49.799: device id: {0.0.1.00000000}.{9703b783-a655-4b0c-b356-3137f35738bc}
20:46:49.799: use device timing: 0
20:46:49.799: User selected new VST plugin: 'C:/Program Files/Steinberg/VstPlugins/TDR Nova.dll'
20:46:49.811: WASAPI: Device 'Microfone (NVIDIA Broadcast)' [48000 Hz] initialized (source: Mic/Aux)
20:46:49.819: [noise suppress: 'Redução de ruídos'] NVAFX redist is not installed.
20:46:49.819: User selected new VST plugin: 'C:/Program Files/VSTPlugins/ReaPlugs/reaeq-standalone.dll'
20:46:49.822: [Loaded global audio device]: 'Mic/Aux'
20:46:49.822: - filter: 'TDR NOVA' (vst_filter)
20:46:49.822: - filter: 'Redução de ruídos' (noise_suppress_filter_v2)
20:46:49.822: - filter: 'Compressor' (compressor_filter)
20:46:49.822: - filter: 'Limitador' (limiter_filter)
20:46:49.822: - filter: 'EQ 1' (vst_filter)
20:46:49.823: Source ID 'background_removal' not found
20:46:49.823: Failed to create source 'Background Removal'!
20:46:49.863: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
20:46:49.863:
20:46:50.398: [win-wasapi: 'Captura de saída de áudio'] update settings:
20:46:50.398: device id: default
20:46:50.398: use device timing: 1
20:46:50.399: [window-capture: 'Captura de janela'] update settings:
20:46:50.399: executable: chrome.exe
20:46:50.399: method selected: Automatic
20:46:50.399: method chosen: WGC
20:46:50.399: force SDR: false
20:46:50.399: [win-wasapi: 'Ryujinx Audio'] update settings:
20:46:50.399: device id: default
20:46:50.399: use device timing: 1
20:46:50.400: [win-wasapi: 'Captura de jogo 2 (Áudio)'] update settings:
20:46:50.400: executable: Ryujinx.exe
20:46:50.400: title: Ryujinx 1.1.1262 - Untitled Goose Game v1.1.2 (010082400BCC6000) (64-bit)
20:46:50.400: class: Avalonia-de6a9838-4155-455e-9a27-f38541e30359
20:46:50.400: priority: 2
20:46:50.402: [WASAPISource::TryInitialize]:[[VIRTUAL_AUDIO_DEVICE_PROCESS_LOOPBACK]] Failed to find window
20:46:50.402: WASAPI: Device '' failed to start (source: Captura de jogo 2 (Áudio))
20:46:50.408: WASAPI: Device 'Caixa de Som Realtek (Realtek(R) Audio)' [48000 Hz] initialized (source: Captura de saída de áudio)
20:46:50.408: Switched to scene 'Gameplay PS5'
20:46:50.408: ------------------------------------------------
20:46:50.408: Loaded scenes:
20:46:50.408: - scene 'Gameplay PS5':
20:46:50.408: - source: 'ezcap 360B' (dshow_input)
20:46:50.408: - monitoring: monitor and output
20:46:50.408: - filter: 'Compressor' (compressor_filter)
20:46:50.408: - filter: 'Limitador' (limiter_filter)
20:46:50.408: - scene 'Gameplay Nintendo Switch':
20:46:50.409: - source: 'Ryujinx Audio' (wasapi_output_capture)
20:46:50.409: - filter: 'Compressor' (compressor_filter)
20:46:50.409: - filter: 'Limitador' (limiter_filter)
20:46:50.409: - source: 'Ryujinx' (game_capture)
20:46:50.409: - source: 'Camera' (group)
20:46:50.409: - scene 'Gameplay PC':
20:46:50.409: - source: 'Captura de jogo' (game_capture)
20:46:50.409: - source: 'Captura de saída de áudio' (wasapi_output_capture)
20:46:50.409: - scene 'Cena 3':
20:46:50.409: - source: 'Webcam' (dshow_input)
20:46:50.409: - filter: 'Aplicar LUT 2' (clut_filter)
20:46:50.409: - filter: 'Background Removal' (background_removal)
20:46:50.409: - scene 'Cena Shorts':
20:46:50.409: - source: 'Placa de Captura' (dshow_input)
20:46:50.409: - monitoring: monitor and output
20:46:50.409: - filter: 'Limitador 2' (limiter_filter)
20:46:50.409: - scene 'Cena 2':
20:46:50.409: - source: 'Captura de janela' (window_capture)
20:46:50.409: - source: 'Webcam (NVIDIA)' (dshow_input)
20:46:50.409: - source: 'ezcap 360B' (dshow_input)
20:46:50.409: - scene 'Cena 4':
20:46:50.409: - source: 'Captura de jogo 2' (game_capture)
20:46:50.409: ------------------------------------------------
20:46:50.411: WASAPI: Device 'Caixa de Som Realtek (Realtek(R) Audio)' [48000 Hz] initialized (source: Ryujinx Audio)
20:46:50.719: ---------------------------------
20:46:50.719: [DShow Device: 'Webcam'] settings updated:
20:46:50.719: video device: Camera (NVIDIA Broadcast)
20:46:50.719: video path:
20:46:50.719: resolution: 1920x1080
20:46:50.719: flip: 0
20:46:50.719: fps: 60.00 (interval: 166666)
20:46:50.719: format: ARGB
20:46:50.719: buffering: disabled
20:46:50.719: hardware decode: disabled
20:46:51.445: ---------------------------------
20:46:51.445: [DShow Device: 'Placa de Captura'] settings updated:
20:46:51.445: video device: ezcap GameDock Extreme
20:46:51.445: video path: \\?\usb#vid_32ed&pid_3212&mi_00#6&cfdc440&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
20:46:51.445: resolution: 3840x2160
20:46:51.445: flip: 0
20:46:51.445: fps: 60.00 (interval: 166666)
20:46:51.445: format: MJPEG
20:46:51.445: buffering: disabled
20:46:51.445: hardware decode: enabled
20:46:51.455: using video device audio: no
20:46:51.455: separate audio filter
20:46:51.455: sample rate: 0
20:46:51.455: channels: 0
20:46:51.455: audio type: WaveOut
20:46:51.463: ---------------------------------
20:46:51.463: [DShow Device: 'ezcap 360B'] settings updated:
20:46:51.463: video device: ezcap GameDock Extreme
20:46:51.463: video path: \\?\usb#vid_32ed&pid_3212&mi_00#6&cfdc440&0&0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
20:46:51.463: resolution: 3840x2160
20:46:51.463: flip: 0
20:46:51.463: fps: 60.00 (interval: 166666)
20:46:51.463: format: MJPEG
20:46:51.463: buffering: disabled
20:46:51.463: hardware decode: enabled
20:46:51.478: using video device audio: no
20:46:51.478: separate audio filter
20:46:51.478: sample rate: 44100
20:46:51.478: channels: 2
20:46:51.478: audio type: Capture
20:46:51.518: DShow: Run failed (0x800705AA): Insufficient system resources exist to complete the requested service.
20:46:51.518:
20:46:51.595: ---------------------------------
20:46:51.595: [DShow Device: 'Webcam (NVIDIA)'] settings updated:
20:46:51.595: video device: Camera (NVIDIA Broadcast)
20:46:51.595: video path:
20:46:51.595: resolution: 1920x1080
20:46:51.595: flip: 0
20:46:51.595: fps: 60.00 (interval: 166666)
20:46:51.595: format: ARGB
20:46:51.595: buffering: disabled
20:46:51.595: hardware decode: enabled
